JAP Model 3
Hi all, I have just aquired and cosmetically restored a JAP Model 3 engine. I would like to know...
this thread has 9 replies and has been viewed 1865 times
Old 01-25-2009, 01:03 PM
smokey smokey is offline
Default JAP Model 3
Hi all,
I have just aquired and cosmetically restored a JAP Model 3 engine. I would like to know what type of spark plug should I use on it and what grade of oil also. I started the engine yesterday for the first time. It starts right away but as when I remove the choke and increase the revs it shuts down. What could be wrong? Does anyone know the points gap?
Glen
Old 01-25-2009, 02:34 PM
ListerDiesel's Avatar
Default Re: JAP Model 3
Is it a Mk3 or a 4/3 engine ?
What sort of magneto does it have and what is the type number of it?
I have books for most of the JAP industrial engines here, but need to pin down exactly which engine you have. Carburettor type would be useful as well, there are three main carbs used.
Peter
Old 01-25-2009, 04:05 PM
Hello Peter,
The cover says Model 3 on it. The carb is an Amal type and the engine serial number is; 3F/9252/5. The ignition is points and condenser type under the flywheel. Hope this info is enough as I would be interested in buying any literature you may have regarding this engine.
Thanks.
Glen
Old 01-26-2009, 03:23 AM
OK, I'll have a look through the books.
The flywheel magneto will be a Wipac unit.
Peter
Old 02-10-2009, 02:44 PM
Viking Viking is offline
I Have the manual for the JAP model 3 type 1 in PDF format if you want it. I'm working on the same engine myself...
Viking
Old 02-27-2009, 03:00 PM
Hello Viking,
Thanks for offering me the manual!! I sure would be interested in having it. What do I need to do? Thanks a lot.
Glen
Old 03-06-2009, 08:40 AM
Just reply to my PM by the mail adr. I included.
I'll email the whole thing.
Viking
Old 03-18-2009, 10:28 AM
Hid you get the manual I sendt you?
Was it what you needed?
Viking.
Old 09-04-2009, 05:16 AM
liamhickey12 liamhickey12 is offline
sounds like its running way to lean/fuel starvation if its cutting out with the choke off...
Old 09-04-2009, 11:36 AM
Monte Stock Monte Stock is offline
Smokey, I have some original JAP literature from many moons ago. I think it is motorcycle related but not sure. Let me know if you are interested and I'll dig it out. I have no use for it and will let it go.
Briggs & Stratton Model 6 (model N) army DAF Small Air Cooled Gasoline Engines 5 11-04-2010 07:27 AM
New guys needs help with Briggs model Z and model KR IHfan Small Air Cooled Gasoline Engines 7 06-16-2008 08:43 AM
Economy model E and model G Tom Gosciminski Antique Gas Engine Discussion 4 02-11-2007 07:20 PM
Model "BUZZ" coil ZZZAAAPPP for a model engine Paul Spence Magnetos, Ignition Coils and Spark Plugs 3 06-14-2006 01:30 PM
