Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
Big Waukesha engine
I thought I'd share some pics I took of a big irrigation engine I saw the other day. This thing...
this thread has 14 replies and has been viewed 1866 times
Old 01-26-2009, 10:55 AM
vern0n's Avatar
vern0n vern0n is offline
Default Big Waukesha engine
I thought I'd share some pics I took of a big irrigation engine I saw the other day. This thing even has a 4 cylinder pony engine.
ID:	47375   Click image for larger version
Old 01-26-2009, 02:01 PM
Default Re: Big Waukasha engine
How did that thing escape being scrapped when prices were so high?? It must be way out in the "way out" somewhere..LOL
Starter motor would probably be an ICK or an FC; I have a batch of manuals left for the bigger engines; I'll look at the pix to see if any look familiar (can't quite make out what's on the tag!!).
Old 01-26-2009, 07:43 PM
dennisfust dennisfust is offline
that would be a interesting engine if you could get it and get it running
Old 01-26-2009, 09:23 PM
bouncingbennyboy bouncingbennyboy is offline
I say put it in a FORD now that would be cool
Old 01-27-2009, 04:01 PM
Default Re: Big Waukesha engine
Well, went thru my bigger Wauk stuff, didn't see anything that looked like this, but this one could well have enough later stuff or aftermarket stuff hung on it that appearance changed.
Looks like only ICK (probably 50 or so CI) and FC (132 CI) used for starter engines; my rem'g manuals show ICK up to 1905ci, FC's from 2894 up. I'm not that familiar with the ICK, don't have a very good pics, only side views; I'd guess this one has FC from it's outline, but it's just a guess.
Vern: If you go by that thing again, and no ones thrown it into the back of a pickup, see if you can get the info off the tag, if you won't risk getting shotgunned in the process.
Old 01-27-2009, 07:24 PM
vern0n's Avatar
I'll see if I can get back by there in a day or so. Here are a couple other pictures I took of the pony motor. I think this engine would look good under the hood of a Pinto. ha ha.
ID:	47506   Click image for larger version
Old 01-27-2009, 09:59 PM
darrin darrin is offline
Is there a injection pump on there ?The big engine that is ,Im thinking Diesel.
Old 01-28-2009, 01:44 AM
(A) I would've guessed the starter motor was an FC, but with a magnifying glass (no blow-up software) I can just make out it's b/s as 21/2x3--; the ICK is 21/2x31/8, so it must be the ICK.
(B) On orig pic #2 there's a mag (greyish colored) just above the oil ?? filter looking grayish canister, and you can just make out (with a mag'fyg glass) sparkplug holes on the same side.
I assume that's some kind of a carb between the two air cleaners; many of these larger engines were available with Nat Gas eqpmt, if there's a gas line out there.
I know Wauk gassers with the ICK went up to 1905ci (6cyl, 7x81/2), but I don't have anything left from that to 2984, which has the FC.
A jobbersinc.com page says the ICK has an alum block; one of my parts catalogs says they have ball and roller mains. I believe there're people looking for them, as they were used for other things as well as starter motors.
Old 01-29-2009, 06:47 PM
vern0n's Avatar
I went and took a picture of the engine tag today, but it doesn't show up very well. Looks it says model GNKR6 U 155 llC. I'm not real sure about the "R". This is a natural gas engine used on a water well for irregation for rice. These engines would run 24-7 for about 3 months to flood the fields.
Old 01-30-2009, 01:24 AM
That's an NKR, sometimes listed as 6NKR, 7x81/4=1905cid; there's another gas/ng etc version, the F-1905-G, but I don't know what the difference is (it's probably in the manual somewhere, but it's 130 pgs) , and a diesel, the NKD.
Wauk first had letter designations, then sometime before 1930 began adding 6- or just 6 to their letter designations of 6cyl engines, making some confusion. In the F-1905-G designation, F is the sixth letter of the alphabet.
They didn't add numbers with the V8's, using H-, or the V12's, using L-, and P- for the V16's.
It's possible, if it's GNKR and not 6NKR, that it could mean the NG version, but there're only a few G engines in my Wauk lists, and i haven't seen G on the front of any others.
In case you're considering picking that up some moonless night, weight of engine with ICK starter and "standard assessories" was 7,577 lbs, but I don't know if that included the 171/2 gals (no typo) oil it needed, NOT counting filters and lines.
The Following User Says Thank You to Bud Tierney:
Old 03-15-2009, 11:14 PM
Rene Elliott Rene Elliott is offline
WOW would hate to have to feed that puppy.
Old 03-16-2009, 10:23 PM
Wayne Riedlinger Wayne Riedlinger is offline
I remember moving Loffland drilling rigs in the early 70s, they had big wauks on them. Most of the rigs had 4 engines on them. If I remember correctly some of the engins were bigger then that one. most of them were propane powered.
Old 03-17-2009, 02:04 PM
FarmallBob FarmallBob is offline
Images: 1
Looks a lot like the big 6 cylinder Wauk natural gas genset at the Western NY Gas & Steam Engine Association ground (Alexander, NY). Note especially the 4 cylinder pony motor. Also the dual ignition - two independent 6-cylinder magnetos.
The engine is running in these photos...
...FB
Old 03-17-2009, 05:14 PM
Boatbum Boatbum is offline
Images: 2
Ok, it's not a Waukesha or gas, but here's my 6 cyl, 160 hp, direct reversing marine Atlas Imperial diesel. There are videos of it running on youtube.
File Type: doc ~$Atlas.doc (162 Bytes, 89 views)
Old 06-03-2009, 12:37 PM
kamsinc kamsinc is offline
We do camshafts for the Waukesha NKR/1905 fairly frequently. They're still in use and being rebuilt by our industrial customers.
Kams, Inc. - Camshaft repair for Waukesha and other indutrial engines.
-Clay in Oklahoma City
Waukesha ICK engine Mac Leod Multi-Cylinder Stationary Engines and Power Units 12 11-11-2009 12:39 AM
Waukesha Engine rwaidelich Antique Autos and Trucks 13 03-17-2009 04:02 PM
Need Help with Waukesha FC Engine Piper451 Antique Gas Engine Discussion 8 07-23-2007 05:31 PM
Waukesha engine Mac Leod Antique Engine Archives 5 11-16-2004 10:19 PM
Waukesha engine John Herald Antique Engine Archives 4 05-20-2003 09:14 PM
