Need help figuring out what type of generator this is
this thread has 21 replies and has been viewed 2495 times
Old 01-31-2009, 10:41:13 PM
Amily95 Amily95 is offline
Default Need help figuring out what type of generator this is
hello and thanks for any help
i have a old onan generator given to me free it all seams good just some very bad hacking on the four large gauge leads that come out of the control box.
2 are for battery i know the other 2 have been cut flush to the whether pack nuts and i have know idea what they are . the motor and gen set turn sooth and the eng. is building comp. so it seams all good ther but i replace the 2 known battery wires but i don't know witch is pos. and witch is neg . i applied power to the leads but nothing happened when i pressed the start button . i think its a wiring issue but i need to find a diagram of the wiring in the control box . i see the 3 large gauge wires coming from the motor and they are labeled with steel tags like a1 s1 . ther is a ford style (not a real ford ) solenoidal . here is all the info off of the metal id plate
m#
205AJ-1E3900/4155H
ser.#
104784315
ac = 115v
phase 1
k.v.a 1.25
watts 1250
dc
volts 8.3
amps 300
watts 2500
bat. 12
Old 01-31-2009, 11:19:49 PM
flyag1 flyag1 is offline
Registered 0
Default Re: Need help figuring out what type of generator this is
m#
205AJ-1E3900/4155H
ser.#
104784315
ac = 115v
phase 1
k.v.a 1.25
watts 1250
dc
volts 8.3
amps 300
watts 2500
bat. 12
Dude whatever you do, please don't BBQ in the house! I've seen a lot on the news about peeps doing that...during this ice storm.
The Following User Says Thank You to flyag1 For This Post:
Old 02-01-2009, 12:05:00 AM
David W. David W. is offline
Looks as if you've got an early AJ genset. Solid machine, but a 3600 RPM variety, which will make it louder than an 1800 one. Cast iron block which ought to last forever. Somebody with a wireing diagram ought to be along before too long and can help you with that concern. Just be careful until they do.
The following link may be benficial.
Click here: Precise Engine Repair - Cummins Onan Engines, Generators and Parts
David W.
Old 02-01-2009, 12:19:25 AM
Registered 0
David W.
David, there is no link?
Old 02-01-2009, 01:51:17 AM
OnanParts's Avatar
OnanParts OnanParts is offline
Amily95, I have the operators and parts manual for your Portastart in PDF. PM your email and I'll send it along.
TJ
Old 02-01-2009, 01:01:38 PM
na i do have a onan 10k gen. running my house as we speak dam ice storm . and i never set the generators or any gas unit within 10 ft of the house .
this just seamed to good to go to the scrap yard . and as far as noise i am going to build an enclosure (not totally sealed just to protect it from the weather and make it easier to move ) and line it with dynamat sound dampener . and also line the tank and some minor spots all around the unit . this stuff will kill sound like no other . i put a 12 by 12 square of it on the enclosure of my 10 k unit and is sounded like i added a lead plate . make sure to use the type for engine firewalls because it can stand up to allot more heat
http://www.dynamat.com/products_auto...remeliner.html
and thanks to all for the help
if i read it wright it is a 2k unit but the dating is what through s me
Old 02-01-2009, 02:53:29 PM
Billy J Shafer's Avatar
TJ could you send me that also.
Old 02-01-2009, 07:09:11 PM
OnanParts's Avatar
Not until you admit hanging out at Taco Bell...
TJ
Old 02-01-2009, 07:14:47 PM
Who told you I was hanging out at Taco Bell. They lied. I am only there four times a week and twice on Saturday. Thanks for the book.
Old 02-01-2009, 07:19:39 PM
thanks tj that help fix some of the issues but i still cant figure witch wires to hook the pos and neg battery terminals to ther is 3 wires coming from the gen. one has A1 A2 .S1 goes to the start button the A2 goes to the starter solenoid A3 goes to a pc board
Old 02-01-2009, 09:06:38 PM
here is som pics of the gen
Old 02-01-2009, 09:11:59 PM
if i can figure out witch wires to hook to i can get ride of the rest and modernize the control system but im not sure witch ones to power to start the motor a1 a2 or s1
Old 02-01-2009, 11:04:11 PM
I will call on Monday and see if I can get a print.
Old 02-03-2009, 09:17:14 AM
just giving it a bump to find out witch wires need to be powerd to start the gen. do i need to power a1 and a2 pos. and s1 neg. or revers ore one of the a wires
Old 02-03-2009, 10:24:49 AM
From what I see the black wire is B-and red Is B+ on the battery. Still waiting on print information.
Old 02-03-2009, 07:27:00 PM
thanks man i just dont whant to do any damege to the gen when i go to start it because some stupid backwards wire
Old 02-05-2009, 08:40:07 PM
ok do i need to supply 12volt + to a1 and a2 (the big white braided wires going to the gen) 12volt - to the s1 (stater im guessing) to turn the gent to start the motor or is it vise versa
Old 02-06-2009, 06:24:39 PM
ok i finally got it to spin the gen put pos on s1 and neg on a1 the starter button apparently is bad so im going to re wire a new one for a car to replace it .
the next issue is ther is gas coming from a hole on the left side of the throttle linkage every time the motor turns is this a sighn of a bad carb. it never fired but did have spark (dam did it ever . my hand sliped and touched the spark plug ) but i don't thing the carb should be spitting gas out of any hole .
Old 02-06-2009, 08:12:54 PM
They make a spark plug tester. Lot less painful. My best is checking the exhaust pipe on a BFA with my arm. Instant BBQ. You may have some trash under the needle of the carb.
Old 02-06-2009, 08:21:10 PM
thanks didn't think to check . the rest of the gas system was all filled with trash so i don't know why i didn't think to pull the carb . and yea ive done old arm trick with my big 15k unit . i was degrease ing it and doing basic maint. and had it running to heat up the oil for a change and slipped and forearm hit on the exast pipe dam that burned like hell but oh well its one of the haz. of working on your own units
Please help: Old Winpower brush-type generator/starter wiring norcalpablo Generators & Motors General Discussion 1 05-30-2007 10:52:20 PM
wincobrush type generator wiring help? frazzled Generators & Motors General Discussion 12 12-06-2006 03:08:46 PM
formula for figuring speed on line shaft Dave Beck Antique Gas Engine Discussion 7 11-05-2006 11:23:47 AM
FM Type "T"....dynamo...generator? Alex Antique Engine Archives 0 02-09-2004 12:24:29 AM
DC Generator Type SK william brown Generators & Motors General Discussion 1 07-23-2003 04:47:14 PM
