Welding Shop
Lincoln LN 25 CV adapter?
this thread has 7 replies and has been viewed 12645 times
Old 02-02-2009, 10:33:39 AM
mr welder mr welder is offline
Default Lincoln LN 25 CV adapter?
hello again I just bought a lincoln ln 25 code # 10233 and am gonna run it off a 1979 sa 200 do I need a cv adapter? If so what is it and whats it do???
Old 02-03-2009, 12:22:07 AM
Rick McKay Rick McKay is offline
Default Re: ln 25 cv adapter?
Do some reading here:
http://www.masterhire.net.au/uploads...anuals/WFU.pdf
You can run a voltage sensing feeder like your off of a CC (constant current) machine like an SA-200, and burning a flux core wire such as nr 211, but you won't get the greatest results. I've run Millers version of a ln 25, the S-32P, but didn't use it long before I decided it's best to stick with stick welding on a CC machine. If you want to run wire, get a CV power source, or a CC/CV power source to run your LN-25. Or get a regular feeder and set it up for hard wire MIG or better yet, dual shield wire.
Keep the sparks flyin'
Rick
The Following User Says Thank You to Rick McKay For This Post:
Old 02-03-2009, 06:45:34 PM
OneWelder OneWelder is offline
Not the best setup but-
Years ago Lincoln made a box for the SA welders that converted CC to CV mounted on outside of machine - was maybe 9" X 12" X 4"deep
This is by memory -I have used a couple of machines like this but have never owned one Perhaps someone else remembers them or are still listed on lincoln site
Voltage sensing wire feeders tend to have a lot of burn backs
At one time LN 25 could be bought as CC or a CV unit
Do you know wich yous is ?
Old 02-03-2009, 09:50:50 PM
dont know that yet code is 10233 but ive tried nr211 wire its just ok my old machine i cant find a wire feed module for it I would like to be able to weld thin metal like body panels or exhaust without getting my tig out or my oxy acet torch I think wire would be the fastest and easiest
Old 02-04-2009, 06:27:52 PM
Default Re: Lincoln LN 25 CV adapter?
I think you should try to find a Lincoln dealer who does repairs in your area. If that does not work contact Lincoln and ask to your district manager contact you
To do body work and exhaust I think MIG would be a better choice than flux cored (innershield ) wire
There is good news bad news
industrial Lincoln feeders are like erecter sets - to go from flux core to MIG get different drive wheels, add solenoid and change gun assy.
You also need to get a cv adapter or cv converter for your
SA 200 as well as a control cable
I suspect it would be much cheaper to get another power supply
Old 02-12-2009, 02:52:32 AM
Round Beam Welder Round Beam Welder is offline
No you do not need a C,onstant,V,oltage box.
Old 01-07-2010, 03:10:27 AM
cybermars cybermars is offline
Ah made it to cyberspace, I never would claim to be a guru, but I have used inner shield. I love it! sticks like glue and never "blows up" like dual shield, especially at the end of a qualifier pass. It works in the wind. Yet the down sides are: all the properties of 7018 stick, A pretty weld if your a welder, otherwise, it will never be glassy like dual shield ( a Constant voltage process). It also has slag. The deposition rate is probably double what stick can do. (constant current, as well as inner shield [and the reason you often see the feeder mounted to mobile equiptment]). Care must be taken to keep the wire (electrode) clean and dry. This was not well known in the seventies. I always make structural welds with stick if I possibly can, it's better. But if your building skyscrapers thats the machine to have, don't ever let it go. If you do, let me know! Keep arching.... cybermars...........
Old 01-14-2010, 04:07:49 AM
Dempster Dempster is offline
Lincoln CV Adapter parts list
http://content.lincolnelectric.com/p...parts/P153.pdf
Lincoln manuals
http://www.mylincolnelectric.com/Cat...ualsearch.aspx
http://content.lincolnelectric.com//...r/im/IM359.pdf
http://www.industrialelectronics.com/htm/lincoln.htm
Lincoln SA-200 JackCroisant Welding Shop 6 04-02-2010 01:04:17 AM
Oil filter adapter Joseph Onan Generators 1 10-11-2008 12:47:49 AM
Cat D8H 24v Starter adapter needed Don Smith Antique Farm Tractors 2 03-06-2008 09:52:15 AM
cck oil filter adapter KC135R Onan Generators 3 04-12-2007 06:41:53 PM
Maytag Model 92M Muffler Adapter Rake60 Maytag Engine Collectibles 2 09-07-2006 12:20:55 PM
