Removing flywheel Homelite 20A115-1
this thread has 6 replies and has been viewed 1939 times
Old 02-06-2009, 04:05:02 PM
Bob Naske's Avatar
Bob Naske Bob Naske is offline
Default Removing flywheel Homelite 20A115-1
I need to get the flywheel off to access points/coil. Need the correct way to do it. It is a 2 stroke single cyl with direct coupled gen.Thanks in advance!!
Old 02-06-2009, 04:14:46 PM
Jim Cobb Jim Cobb is offline
Cool Re: Removing flywheel Homelite 20A115-1
LOL , I have been trying to get the flywheel off a Continental 3HP now for a long time no luck . But on other engines they will pop on and off with ease .
good luck on your quest .
Jim
Old 02-16-2009, 08:11:49 PM
Smile Re: Removing flywheel Homelite 20A115-1
Hi Bob ,
I was finally successful in removing the flywheel from my engine.
If you go to SMALL AIR COOLED GASOLINE ENGINES forum and look at removing flywheel on small eng. date 2-9-09 you will see the advice that I recived , But I think heat did the job for me.
Hope this helps.
Jim
Old 02-16-2009, 08:18:50 PM
Kimbra Dean Kimbra Dean is online now
Default Re: Removing flywheel Homelite 20A115-1
Be careful with the heat, don't set it on fire and have extinguisher handy just in case.
Old 05-19-2010, 06:51:37 PM
onegin201151 onegin201151 is offline
hi; i used a three jaw puller by taKING THE ARMS OFF AND USING SOME LONG BOLTS TO SCREW INTO WHERE THE ROPE PULL SREWES INTO, TOM
Old 05-20-2010, 12:34:33 AM
John Newman, Jr.'s Avatar
Watch those bolts so that you don't go in too far with them and drive one right into the magneto coil. Been there - Done that.....
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 05-22-2010, 04:26:21 PM
The flywheel puller is built in on that engine.Just back the nut out against the starter plate and keep turning.It will pop the flywheel off.Wish everyone made em like that.
Removing flywheel or BobM Antique Gas Engine Discussion 4 04-28-2008 03:22:22 PM
Removing a 2hp IHC Famous flywheel Johnny T Antique Gas Engine Discussion 6 02-05-2008 08:05:50 PM
Removing flywheel? Chris J Antique Gas Engine Discussion 15 07-26-2007 06:50:33 PM
Removing an LA flywheel Norm Antique Engine Archives 6 12-04-2001 09:50:26 PM
removing flywheel steve hales Antique Engine Archives 7 11-20-1999 08:07:31 PM
