What kind of shaft does a Generac/Negano 6.5HP have?
I've looking for a motor to replace a blown-up Briggs 6.5 OHV on a Powermate generator. I ran...
this thread has 1 replies and has been viewed 378 times
Old 02-12-2009, 11:31 AM
steig lindo steig lindo is offline
Default What kind of shaft does a Generac/Negano 6.5HP have?
I ran across a good deal on a Generac 3500 with a dead generator head, and a good Generac 6.5 engine. I believe this is the Negano motor with the filter and pressure lube, a very nice motor.
Does anyone know if this would fit my Powermate head? The only stuff I've been able to find on Generac shafts shows an oddball setup with a straight section and a tapered section (much like the crank on my Briggs), but then another straight, threaded section. I assume this is to fit some special, dedicated, rotor?
I know they made a similar machine only with a Briggs motor, but it seems quite possible it could have used a special crank on the Briggs, or a different rotor.
Old 02-13-2009, 10:45 AM
K D Redd K D Redd is offline
Default Re: What kind of shaft does a Generac/Negano 6.5HP have?
I think, BUT DO NOT KNOW FOR SURE, that the tappers on the crankshaft of engines for sensrator use are all the same. The only sure way to know is to buy the other unit, disassemble both and see if you can swap the parts around.
Kent
Old RV Generac Arthur Generac Generators (SEARS, etc.) 9 09-11-2009 09:37 PM
Converting A Vertical Shaft Lawnmower engine to a horizontal shaft Jordan Garden Tractors / Mowers / Scooters 18 06-16-2009 04:49 PM
Generac 5Kw Ed Stoller Generac Generators (SEARS, etc.) 23 05-30-2009 09:38 PM
Generac ChrisMar Generac Generators (SEARS, etc.) 1 02-10-2008 05:49 PM
generac pwest Generac Generators (SEARS, etc.) 1 09-14-2004 11:51 AM
