Need help identifing engine? (Economy)I have an engine here i can't find any info on. serial number is 305394 RPM 475 Model - 3fw ...this thread has 7 replies and has been viewed 651 times
serial number is 305394 RPM 475 Model - 3fw any help is appreciated thanks, Justin |
It's an Economy with some wierd flywheels.
I've seen economys like that with a mud pump style pump.
So do you think the flywheels are original, did any economy's come factory with battery and coil setup?
Looks like the governor was timed wrong at some point and broke the piston skirt.Seen that before! Chip
That engine is a 3 HP that originally had a WICO EK magneto to fire the spark plug. The part of the spark plug mount where the WICO would have mounted has been broken or cut off. Glenn Karch discusses the flywheels like yours in his book on Hercules engines. They were built with smaller diameter, heavier flywheels to fit applications where there were space limitations.
Here is my 3hp FW with Wico PR mag
More Pics: http://www.oldengine.org/members/sba...cules3pump.htm ![]() I also had a 1 1/2hp with small flywheels, but sold it several years ago. More Pics (taken a year before I purchased the engine): http://www.oldengine.org/members/sba...cules1pump.htm
Steve Barr http://www.oldengine.org/members/sbarr Fight "Global Warming" Get rid of the heat source....the SUN
| Need help identifing engine? (Identified as STOVER) | trudsmtuner | Antique Gas Engine Discussion | 9 | 03-28-2009 11:47 PM |
| Identifing the maker of my engine | Judd Rogers | Antique Gas Engine Discussion | 2 | 07-09-2008 10:49 AM |
| New to forum, need help identifing old edger engine | bfaulguy | Small Air Cooled Gasoline Engines | 2 | 05-24-2006 12:25 PM |
| Need help identifing an engine cart | Mike Harper | Antique Gas Engine Discussion | 0 | 04-02-2006 11:23 PM |
| Need help identifing engine | Mike | Antique Engine Archives | 1 | 12-13-2001 08:15 PM |
