Welding Shop
Coat Hangers as Welding Rod
this thread has 40 replies and has been viewed 14676 times
Old 03-10-2009, 01:14:06 AM
Beanscoot Beanscoot is offline
Default Coat Hangers as Welding Rod
Occasionally I have not had proper welding rod on hand for plain steel welding and have used a coat hanger as a rod. Is this okay or a bad idea? So far I have used it on fairly low stress items like car exhaust pipe repair.
Old 03-10-2009, 08:09:26 AM
Default Re: Coat hangers as welding rod
Never heard of that.But I suppose if you needed to get your exhaust put together it would work.I don't think it would hold up under any stresses,and you must get alot of spatter with no sheilding on the rod??Let's see what others have to say!!
Old 03-10-2009, 08:39:39 AM
Rick McKay Rick McKay is offline
I have used coat hangers for several years as my primary steel filler rod for oxy-acet welding. The best hangers are the ones from the uniform companies. The anti-rust coating is very thin on those hangers. The coating is thin enough not to interfere with the quality of the weld, yet thick enough to be effective as a rust inhibitor. If you try to use a plain steel hanger with no coating, even the slightest amount of rust will bugger up you weld. I usually cut the hook off and straighten a bunch at a time and keep them right in the tube with by brazing rods. I've used them for many different jobs with great results. It would be interesting if someone would perform a tensile test on to see how it stands up to "store bought" filler.
Rick
Old 03-10-2009, 08:50:11 AM
Steve Kunz's Avatar
Thats one of the oldest tricks in the book. I've used them for years without any problems.
Old 03-10-2009, 10:15:58 AM
KeithW's Avatar
KeithW KeithW is offline
Default Re: Coat Hangers as Welding Rod
I will not say it won't work as I expect we all have done it. The problem is that you have no idea about the quality or strength of the steel in the hanger. It could be wonderful or it could be s**t. For an exhaust pipe, yes. For a steering linkage, no.
keithw
Old 03-10-2009, 10:19:10 AM
Tom Weatherford Tom Weatherford is offline
I worked at a body and fender shop when I was in high school (1968). The fellow there said they were the best for welding the parts back on. Of course he was using ox /acetylene torch. Hadn't invented mig yet.
Tom in VA.
Old 03-10-2009, 10:46:14 AM
Randy Hart's Avatar
Randy Hart Randy Hart is offline
Images: 2
I've used them for years, I don't do it often enough to keep good clean rod around so the old coat hanger fills the bill..
As far as what to use it on and what not to.. thats the other part of the job..
If you weld the steering arm back on your kids lifted 4x4 pickup you BETTER know more than us who do gas welding now and then.
At one time the policy at work for steam pipe was a gas weld root pass before the arc welders began to fill and cover
He who dies with the most STUFF wins!
Old 03-10-2009, 11:19:08 AM
Thanks for that input! I did forget to mention that this was oxyacetylene welding, but you folks figured that out.
I am only considering non-critical welding like exhaust, shrouds, fenders and the like. I wasn't aware of the concern about rust on the filler rod, as a lot of my welding is on rusty stuff, especially the exhaust pipes. But the coat hangers I have used were not rusty.
When MIG welding the rust really wreaks havoc.
Old 03-10-2009, 12:26:20 PM
Ben Hadd, eat 'yer heart out!
Mike
Old 03-10-2009, 01:20:44 PM
You can't beat hangers for aluminized exhaust parts.
As for welding ANY steering thing......we USED to with no second thoughts.....(NOT with coat hanger by the way)
Not any more.......
Old 03-10-2009, 01:26:47 PM
MoRo's Avatar
MoRo MoRo is offline
Mike
Ha! Mike, you had the same thought as me. I'd say coat hangers are just fine. Ol' Ben does all his 0-0 Stamp boiler repair with 'em. Nobody's ever lived to complain about the work either.
Old 03-10-2009, 01:43:49 PM
OneWelder OneWelder is offline
This is an old practice that - years ago coat hangers were made out of a much higher grade steel than now, now they have a lot more impurities.
Welding rusty exhaust pipes with coat hangers would work just a little harder. - Yes I have done it,and will do it again if necessary.
Gas welding rod (I have not bought any for couple of years) was pretty cheap,and you will find that 1/16 inch will Work better than the larger Dia. coat hanger or welding rod- it is closer to the thickness of what you are welding- also less impurities to work out
Old 03-10-2009, 02:20:45 PM
Frank Martin Frank Martin is offline
Coat hanger works. I wouldn't use it for anything I give a s--- about though. If I had any welding rod around at all, I wouldn't even think about using the coat hanger. Welding rod is so cheap that it's not even worth the effort of messing with the coat hangers and settling for a substandard weld unless its an emergency.
Old 03-10-2009, 10:05:33 PM
PFT's Avatar
PFT PFT is offline
Images: 31
I'm surprised no one mentioned bailing wire. Everybody I know uses it for exhaust, sheet metal and other light duty jobs. The wire seems to work better after being run through the bailer, wipes off some of the excess protective coating.
PT
Old 02-11-2016, 05:22:11 PM
wmusta wmusta is offline
Well I figured this wasn't worth a new thread so I'll dump it here.
Not quite coat hangers but I use the strips out of used windshield wiper blades for cheap TIG filler rod.
The Following 2 Users Say Thank You to wmusta For This Post:
Old 02-11-2016, 06:06:13 PM
Steve Kunz's Avatar
I had one of those rods from a windshield wiper blade stuck all the way through my hand!
I was changing blades, sliding the old one out and it got caught on something. I was in a hurry and decided to keep pulling and force it out. The rubber stretched out then it broke free, I thought the rubber just slapped me on the hand, it did not really hurt. I could not believe it when I looked down and saw the rod stuck all the way through my hand!
Steve Kunz
Old 02-11-2016, 06:48:38 PM
uglyblue66 uglyblue66 is online now
fast getting to a point you can't even find metal coat hangers. I try to get them from folks cleaning out older folks homes and stuff that have the old 1's.
I don't use them for welding but perfer them in the closet with my clothes hanging on them. As much as they flex under the load I put on them i would say they must be purty strong metal.
Alot of stuff was welded with coat hanger on my grandpals farm. that is what was handy. Made Grandmal cuss but she got over it.
Old 02-11-2016, 07:06:37 PM
Friend was racing down in Mexico a few years back and tore a suspension part in half, kept going but at a slower speed. Going thru a small village at night she spotted a guy that had built a multi story home out of school buses and figured he knew how to weld. She managed to call him down from the top floor of his mansion and although neither spoke the others language the broken part was obvious, he drug out a set of tanks and welded the part together with coat hangers. She finished the race that night, then totaled the car the next day.
Old 02-11-2016, 07:12:56 PM
Paul Johnson Paul Johnson is offline
Early 50's 1/4 mi. Stock cars on a shoe string diet, gas and hangers equaled many crash/nerf bars. I am sure many drag links too.
Old 02-11-2016, 07:13:16 PM
I've welded a many a door on a dirt stock car with coat hangers, as well as exhaust headers, and similar things. Always worked great for me.
The Following User Says Thank You to Pat Barrett For This Post:
Final coat to seal everything? Keith Thomas Antique Gas Engine Discussion 7 01-22-2009 10:17:59 PM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46:02 PM
Polished brass:To coat or not to coat? Lou Quirch Antique Gas Engine Discussion 5 01-03-2005 08:11:36 PM
Clear coat John Bunting Paint Shop 1 01-26-2004 06:00:13 PM
Clear Coat? Ron Paint Shop 2 06-09-2002 09:43:14 PM
