Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
1904 "Waterman" 2 cyl-2-stroke inboard
Guys: My grandfather owned this little 2 cylinder inboard for many years. After his passing, my...
this thread has 21 replies and has been viewed 7144 times
Old 03-14-2009, 07:58 PM
Tom Schaech Tom Schaech is offline
Default 1904 "Waterman" 2 cyl-2-stroke inboard
Guys:
My grandfather owned this little 2 cylinder inboard for many years. After his passing, my uncle loaned it to a local museum to display. I know the year and make, but anyone out there have any idea if it's rare or not and an approximate worth? We may be in discussion to retrieve it as the museum is not displaying it as the agreement stated. In either case, I'm keeping it in the family.
Old 03-14-2009, 08:33 PM
Doug Kimball's Avatar
Doug Kimball Doug Kimball is online now
Images: 71
Default Re: 1904 "Waterman" 2 cyl-2-stroke inboard
Tom,
Nice looking engine. They are not extremely rare but the copper jackets & light weight make them pretty collectible for a 2-cycle marine engine. Could not see the carb in photo which is usually Breeze or Kingston 4 or 5-ball carburetor. I would say probably in $1000 range.
Old 03-15-2009, 05:33 AM
Exclamation Re: 1904 "Waterman" 2 cyl-2-stroke inboard
I have a waterman K-2 like yours, built by Pausin Engineering in 1917. It is mounted on a fire pump. the design goes back ti the 1890s, and the engine has seen many uses. it has ales been canned a Dispro engine, Dispro is a trade mark of the Disappearing Propeller Co.. These marine drives were retractable to allow shallow water operation. I agree the engine is unique, and makes a great display piece. The engine design was used into the 1930s.
Old 03-15-2009, 02:50 PM
Derek Pollard Derek Pollard is offline
Hi my K1 has breeze interesting carburater DEREK
Old 03-15-2009, 05:07 PM
JoeCB JoeCB is offline
Tom, check this out... just posted on the aomci site a Dispro engine single cly but looks a lot like yours
Joe B
http://ebay.com/ebaymotors/Silent-Dis-Pro-Disappearing-Propeller-Marine-Boat-Motor=item180336965872
Old 03-19-2009, 02:20 AM
That is the K-1 series engine. Rated at 21/2 HP. The K-2 twins were rated at 5 HP. The watermans were made up to 4 cylinders!
Old 04-12-2009, 07:18 PM
i need to find a good copper waterjacket for a single cyl. dispro. Waterman would work fine too, anyone know of any?
Old 04-21-2009, 09:12 PM
solarrog's Avatar
solarrog solarrog is offline
I have 3 of the K2 Waterman's, Most were sold in the teens and twenties, 2 of mine are the fire pump versions and one is the canoe motor type, I also have a couple of the outboard motors in my collection. I think Doug about is pretty close as to value. I see a few up forsale every year. You gotta grab them when they show up.
Roger
Roger, collector of antique outboards, small air cooled engines,
Fremont, Ca 510-226-2414
Old 08-15-2010, 10:09 AM
OilEngine OilEngine is offline
Its a British make called Watermota, dates from mid 1920's, and the model is K2.
I have a hand book, I think.
Value, well in the UK I would say in running order around £350
Kevin Whittle
Old 04-19-2011, 08:33 PM
JimC JimC is offline
I just purchased what I assume by photos and Wendell, is a Pausin but no nametag or anything to identify it by. The distributor cap is missing so maybe this had some info on it. I would appreciate some photos of the cap and inside if possible. No wires to show how the ignition was hooked up either. All that is there is a home-made handle and a pin with a roller on it. The gears for the timing are stripped so need to make new ones. See you at a show sometime.
Jim
Old 04-19-2011, 11:32 PM
Pausin Engineering, of Newark NJ only made pumps for about 2 years. The Waterman engine design has been made by quite a few manufacturers. My Pausin has a unique chain drive Bosch magneto, not a distributer. Your engine might be a Waterman or Dispro. The Pausin has a brass medallion soldered to the rear cylinder, with the company name on it.
Old 04-21-2011, 12:30 AM
Axtion Jim S Axtion Jim S is offline
Hi Tom
I have a K-2 Waterman that I picked up 2 years ago . I was happy to pay the fellow 1000 for it.
The fly wheel on mine has been changed to one made of steel plate, but the rest of the engine is still the same as it was when it was removed from a boat complete with the transmission and the wooden sils that it sat on in the boat.
I`ll see if I can load up a photo of it. or you can see it Old MARINE ENGINE, web site.
Jim
Old 05-05-2011, 11:34 PM
Hi Axton Jim S
I certainly would like to see some photos of your Waterman. I desperately need a distributor or at least photos so I can make one. I could have my friend in Bradner take measurements and photos if that would be okay with you.
Thanks.
Old 05-06-2011, 12:19 AM
Hi Jim C My waterman has a timer not a distributor, you may have a Dispro or ? Have your buddy in Bradner give me a land line anyway.
The Following User Says Thank You to Axtion Jim S:
Old 05-06-2011, 04:29 PM
Hi Jim. It could be a timer as I am not too sure what is missing, just from photos on the internet. I will get Ruby (you met her) to contact you and make arrangements to see and photograph your timer. No wiring with this engine so need to know how and where it was wired and was the spark provided by Model T coils? Will you be at any of the shows in the Interior? Thanks, Jim
Old 05-12-2011, 08:58 AM
Question Re: 1904 "Waterman" 2 cyl-2-stroke inboard
Between the flywheel, is there a bevel gear or a chain sprocket?
Old 05-12-2011, 01:36 PM
Richard Durgee Richard Durgee is offline
Andrew, in post #3 above you said these copper top engines went back as far as the 1890's, I do a bit of research on old marine engs and would like to know your source on that info if possible.
Waterman Marine Motor Co. founded by Cameron B. Waterman a Yale Attorney Designed the Porto outboard in 1906 and began mfging in that year, by 1908 he added small inboard engs these were cast iron engs, Waterman added the copper jacketed engs a few years after that. None of the inboards were waterman design he bought them from other mfgrs !
Old 05-13-2011, 12:46 AM
Hi JimC, Go to the old marine engine web site and on the search window print in Waterman K2 or K1. There is tons of info that will help you find your ansewer. The engine I have is at my home shop, I have so many of these engines that they are stored in three differant spots, that way if something happens I won`t loose all of them.
Cheers Jim
Old 07-10-2011, 07:22 PM
Hi JimS
I now have a timer for the "Waterman". I am working on a Vivian and need info re retarding/advancing the mag as it only has a direct drive and no apparent easy adjustment with the mag that was on the engine. Any help appreciated.
Old 07-11-2011, 01:11 PM
Hi Jim
What model and hp of vivian do you have. I personally have two of them. I also have some litriture on them.
Robert on Van Island has a lot of the stuff on the Vivian. I have his land line numbers, if you want them email me. He`s a good guy to talk to.
Cheers Jim S
Union Pacific RailFest 2007- "844" & "3977" Robert M Stationary Steam & Traction Engines 18 10-29-2007 09:05 PM
Question? "Oil Field" or "Industrial" David M. Hammer Oil Field Engines 1 12-27-2005 11:15 AM
Identity of diesel with "RMC" & "Chromidum" logos? Jonathan B Vintage Diesel Engines 0 06-26-2005 05:06 AM
Fairbanks "Jack of all Trades" "T" Ser# List??? Shane Ball Antique Engine Archives 1 07-29-2003 10:37 PM
