Farymann / Briggs Single Cylinder Diesel
this thread has 7 replies and has been viewed 5468 times
Old 03-16-2009, 06:31:34 PM
JALaswell JALaswell is offline
Default Farymann / Briggs Single Cylinder Diesel
I have recently acquired a new Farymann Diesel from the time they were allied with Briggs and Stratton. If the information I have is correct It would have been built prior to 1986. It is Model: 15A430-0111001 34 K4 5415 3600. It is complete less a power output shaft from the flywheel and what I would think it should have is some type of shroud with a screen around the output shaft to all air intake to the cooling fan similar to my CH-23 Kohler. I would appreciate any information anyone can give me as to the specifications of this engine and where I might be able to purchase a Flywheel Shroud and output shaft. I wish to use this engine to power a rototiller on the back of my John Deere 317 Garden Tractor. It will require a pulley on the output shaft of the engine. The engine is complete otherwise and has never been fueled or had Oil put in it. Thanks for any help you can provide.
Old 03-16-2009, 09:44:45 PM
Jeff Conner Jeff Conner is offline
Default Re: Farymann / Briggs Single Cylinder Diesel
Try here....
http://www.farymann.de/en/dealersearch.aspx
The Following User Says Thank You to Jeff Conner For This Post:
Old 03-20-2009, 08:48:26 AM
vern0n's Avatar
vern0n vern0n is offline
Can you post a picture of your engine. I have an incomplete engine and wonder if it is like yours. I might sell.
The Following User Says Thank You to vern0n For This Post:
Old 03-31-2009, 03:13:37 PM
Hi VernOn:
Thanks for the reply.
I haven't figured out how to post pictures to this site yet or have not been given the privilege.
I have pictures of the 4 sides of the engine and if you will send me your eMail address I will be glad to eMail the pictures to you.
jalaswell@academicplanet.com
Thanks again,
Jack
Old 04-02-2009, 03:35:34 PM
Here are pictures of the four sides of this engine;
Model: 15A430
Old 04-03-2009, 09:11:49 AM
vern0n's Avatar
Sorry, I don't get on this board very often. That does look a lot like my engine. I'll have to look what's on the front of it.
Old 04-19-2009, 07:52:25 PM
Hi Jeff:
I eMailed the listed US represenatives that had that capability and did not receive a single acknowledgement of my eMail. I then eMailed Greaves Farymann since they bought Faryman. Again no answer. I then eMailed Farymann directly in Germany. I wrote the eMail in English and received the following reply: (I am including Mario's eMail address for your future reference.)
m.diefenbach@farymann.de
Dear Jack,
first of all, we thank you for your mail of April 12th which I will answer
with pleasure of course.
I would like to send all existed information about your engine by
airmail to Kaufman in Texas first so you will be able to check all
technincal details and informations exactly and if there is any
question or request , please feel free to contact me again.
Best Regards from Germany
MARIO
Thanks for your answer!
Jack
Old 05-08-2009, 02:31:42 PM
Since my last Posting Vernon delivered his engine to Kaufman Texas where I picked it up. The Power Shaft fit the Farymann Briggs engine and is adequate for my use. My new engine from Vernon is a Farymann 22L0577 - N - 3000. Parts of the engine are missing. The cylinder seems to have little wear but it apparently has sit outside a lot and was very rusty and the paint was missing. I cleaned it up and painted it. It is missing the upper shrouds, Rocker Arms, Push rods, Rocker Arm covers and all plumbing. The Rod, Crank, Cylinder, Piston all seem to be in good shape. The Plastic cooling fan is not usable as it is broken in several places.
The Farymann Briggs started on the first crank after priming the fuel system. It ran for 5 minures very smoothly at Idle, 5 minutes at half throttle, and about 5 minutes at full throttle when the plastic cooling fan started breaking up.
This appears to be the greatest weakness in these air cooled engines as the plastic ages.
I am attaching pictures of the 22L0577 engine as it is now.
Farymann 22L 1C.JPG   Farymann 22L 2C.JPG   Farymann 22L 3C.JPG   Farymann 22L 4C.JPG
Single cylinder Homelite Diesel generator ID cummins88 Generators & Motors General Discussion 2 01-09-2009 12:59:22 PM
Farymann diesel engine info Tom Geier Vintage Diesel and Oil Engines 3 10-06-2008 06:01:30 PM
Flywheel removal on Farymann Diesel Ed Deis Antique Engine Archives 5 09-13-2004 07:41:23 AM
Fairbanks Morse Model 45 - Single Cylinder Diesel Ted Rozanski Antique Engine Archives 0 07-29-2002 01:11:32 PM
Single Cylinder Diesel Onan Steve Onan Generators 0 10-14-2001 03:46:58 PM
