Go Back   SmokStak > SmokStak® General Discussion > Auctions of Engines, Tractors and Old Iron
Road Gear - what tractors had them?
Anyone know what tractors in the late 40's and 50's had a road gear? thanks
this thread has 20 replies and has been viewed 869 times
Old 03-19-2009, 10:21 PM
Jake Jacobs Jake Jacobs is offline
Default Road Gear - what tractors had them?
Old 03-19-2009, 10:24 PM
casesteam12's Avatar
casesteam12 casesteam12 is offline
Default Re: Road Gear??? What tractors had them?
In the late 30's or early 40's Minneapolis Moline made the comfort tractor that had a modern enclosed cab on it. If memory serves me correctly these would run 40 mph.
Brad
Old 03-19-2009, 11:27 PM
bocephus_k6 bocephus_k6 is offline
Default Re: Road Gear - what tractors had them?
Friday tractors would cruise somewhere around 50 or 60 MPH...
Brian
Old 03-19-2009, 11:43 PM
Mike in NC's Avatar
Images: 62
Silver Kings could cruise around 45 MPH or so.
Old 03-19-2009, 11:58 PM
Bob Shannon Bob Shannon is offline
My 8N Ford has an add on Sherman overdrive. Goes faster than I care to drive it.
Old 03-20-2009, 01:18 AM
slug slug is offline
I saw a case L that had a road gear. It was so they could pull the separator from place to place. John
Old 03-20-2009, 01:35 AM
Mike in NC's Avatar
Images: 62
The Farmall F-Series had an add on overdrive.
Old 03-20-2009, 11:10 AM
HBurk HBurk is offline
Had an F-20 one time with a road gear. Close to 20 MPH.
Old 03-20-2009, 02:32 PM
HerbyReed HerbyReed is offline
The Farmall M had a road gear, it was 5th and quite a trick to shift from 4th to 5th without stalling out. The M had no speedometer but we always figured top speed was around 25. A little care was needed on cornering though, with the tricycle front end it would have been real easy to upset that tractor.
Old 03-20-2009, 02:35 PM
Mislaid my CO-OP notes; it was the Chrysler 6, Dodge truck driveline tractor produced by the farm co-ops in 35/6 up thru postwar, when the design was continued by Custom, and then smaller producers like Jacob? Love and Dave? Friday, up into the mid 50's, as I recall.
It had good road speed, so farmers could move quickly between fields or fields/town.
One advertising gimmick reported was one got a speeding ticket, but can't recall without notes or review whether was supposedly making 25 or 35, but I believe ir was 35.
Custom also used Chrysler Cptn straight 8's in addition to usual 6's; don't recall anything on how fast they 'd go.
Love and Friday added 2-speed rear end to get the reported 55-60; believe highest reported figure I saw was 62
Old 03-20-2009, 03:51 PM
My Farmall "M" will get about 22 MPH.
Old 03-20-2009, 06:17 PM
I've heard stories about some North Dakota farmers being frustrated about the slow road speed on the unstyled John Deere A's and B's. It seems they discovered a poor man's remedy by removing the link that automatically shifts the transmission to low range when shifting into reverse. They had found that the road speed in reverse hi-range was faster than any of the foward gears.
If this was true that would be quite a ride!
Old 03-20-2009, 10:30 PM
Ed Malcom Ed Malcom is offline
Email Not Working
when i was a kid a long time ago my dad had a case model RC with an add on road gear.
Old 03-21-2009, 09:26 AM
ELIDAS ELIDAS is offline
My Centaur KM is supposed to have a "road" gear. These were used for highway mowing and needed to travel. I would think that 20mph would be "interesting".
Old 03-21-2009, 10:11 AM
MoRo's Avatar
MoRo MoRo is offline
That musta been the 4-speed transmissions. My dad's '49 A had the 2-stick 6-speed, for which road gear was faster than the "hi" reverse.
I learned to put the main lever about half way into reverse, and the other lever halfway into hi. She'd sail backwards pretty good. Worked nice for bucking hay up to the stack.
The Following User Says Thank You to MoRo:
Old 04-24-2009, 05:43 AM
20minnie 20minnie is offline
Not sure if Silver Kings had a road gear per say. My understanding is that they were geared for speed. An old man I met once told me a story of passing every thing on the road with a Silver King. However the tractors did not have the low range to pull well and would get stuck fairly easy in fields. Many owners found the solution. They would mount the rear tires with the tread going in oppisite directions. This was to insure that one tire would pull in any direction and spin or walk the tractor out.
Old 04-24-2009, 07:18 AM
Happy Old Iron Happy Old Iron is offline
Cool Re: Road Gear - what tractors had them?
Silver kings exist with normal, high and very high gearing.
The slowest we had would run only like 12 to 15 mph, the fastest at least 35 mph.
The Following User Says Thank You to Happy Old Iron:
Old 04-24-2009, 02:21 PM
Molinegb Molinegb is offline
MM 's UDLX was rated at 38 Mph. I have a 1940 MM ZTS that has road gear which is blocked out because it came from factory on full steel. Also early MM U's had similar rear gears to the UDLX,UOPN but did about 22 mph.
Old 04-24-2009, 03:12 PM
MCanady's Avatar
MCanady MCanady is offline
What about Allis Chalmers Tractors Promotion they had in the 1930's to sell Rubber Tires. They added High Speed Gearing to some of their Tractors and hired Barney Oldfield and other drivers to drive the tractors on race tracks at Fairs around the country. These were not meant to be sold but some did get sold and I read a story about one that a collector found and restored sometime ago.
The Following User Says Thank You to MCanady:
Old 04-25-2009, 10:40 AM
manmrman manmrman is offline
Cockshutt built a base rear-end that would withstand future horsepower increases. Two bull gears with bearings on each side were designed into a four-walled gear case and connected with a sliding spur gear transmission, six forward and two reverse. With a 1.6 mph 1st gear, the Model 40 was the slowest tractor in its horsepower class! This “straight line” (no u-joints) drive to the differential proved popular with tractor pullers long into the future and was even employed on the much later 560 and 570 models
New Gear Source: Martin Gear + Sprocket PaulGray Antique Gas Engine Discussion 3 01-22-2008 09:54 AM
Sattley cam gear and crank gear timing Judson Antique Gas Engine Discussion 2 11-18-2007 07:21 PM
On the side of the road... Toy-Man01 Antique Gas Engine Discussion 7 09-17-2007 11:54 PM
Long day on the road Randy Hart Small Air Cooled Gasoline Engines 9 01-31-2007 11:07 PM
Old generator up the road Bruce Sutton Generators & Motors General Discussion 0 10-08-2003 09:19 PM
