Recoil to elec start B&S 19G412 type 1187e
Code 9912161B application : Generac mod 09719-3 .No faults with unit Problem is operator's lack of...
this thread has 1 replies and has been viewed 584 times
Old 03-21-2009, 02:30 AM
B n G B n G is offline
Default Recoil to elec start B&S 19G412 type 1187e
Code 9912161B application : Generac mod 09719-3 [5kw].No faults with unit Problem is operator's lack of ability to pull start hence conversion does anyone know if this eng was used in applications such as riding lawn mowers etc ? B&S manual shows it as a option . my thought were to look for a dead mower to get flywheel, starter, & cover & hardware . installing charging system & batt would be unneccesary as it is simply an emergency gen that could be spun over with jumper cables from a vehicle thru a automotive solenoid starter [Ford] . Info as to what will fit etc., & knowledgable comments greatly appreciated regards Butch
Old 03-21-2009, 10:53 AM
K D Redd K D Redd is offline
Default Re: Recoil to elec start B&S 19G412 type 1187e
I have done what you propose on Tec. powered generators. I do not see why it will not work. The only thing is I would install the 12 charging system from the dead mower engine if you find one. You do not know if sometime in the future you may want/need to install a starting battery on the engine,
Kent
Thordarson Elec. Coil? Brady Magnetos, Ignition Coils and Spark Plugs 3 05-31-2007 09:30 AM
Briggs 5S Recoil Start Rake60 Small Air Cooled Gasoline Engines 19 12-16-2005 12:33 PM
Holzter-Cabot Elec. Co. Brian Tefft Generators & Motors General Discussion 0 10-12-2004 09:34 PM
GE Elec-Trak chan mason Generators & Motors General Discussion 5 10-26-2003 10:39 AM
Kohler Elec Plant Smoke Kohler Generators 0 09-16-2003 10:57 AM
