Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Briggs and stratton low spark (HELP)
this thread has 5 replies and has been viewed 6637 times
Old 03-25-2009, 02:14:31 PM
Ricky Harris Ricky Harris is offline
Default Briggs and stratton low spark (HELP)
I havea 8 hp briggs 82 mod. It had no spark on the old coil so I change it to electronic coil and now have low spark.This coil ran fine on the other 8hp engine.What am I over looking.
Old 03-25-2009, 03:26:49 PM
Sky
Default Re: Briggs and stratton low spark (HELP)
Weak magnets possibly? There was probably nothing wrong with the original set up. Most of the time you just have to burnish or replace your points and reset them to .020 and ocasionally the replacment of the condencer.
Old 03-25-2009, 04:19:05 PM
K D Redd K D Redd is offline
Be sure you have the coil to flywheel spacing is correct. I think .010 is the spec. but I use a business card. Lossen the coil and pull as far away from the flywheel as possible and tighten the screws. Turn the flywheel so the magenets are below the coil, slip business card between the coil and the flywheel and loosen the screws. After the coil has been atracted to the flywheel tighten the screws. Now turn the flywheel to remove the business card and check your spark.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 03-25-2009, 05:08:25 PM
Ed Radtke Ed Radtke is online now
Be sure coil is mounted correct side out.
The Following User Says Thank You to Ed Radtke For This Post:
Old 03-26-2009, 01:01:10 AM
I change the condencer out for a new one before I went to the electronic one.I am gaping it to close I allways just got it as close as possible .010 to .015 should do OK.I think the big problem is there was rust on the flywheel.I have cleaned it off with sand paper and wire brush and it could be the magnet.I have a flywheel off of a vertical one.Does any one know if this could be a permanent fix or temporary.
Old 03-29-2009, 10:42:12 AM
THANKS It was the flywheel,changed it out and got it to start
Briggs & Stratton NPW hitnmiss Small Air Cooled Gasoline Engines 3 03-26-2009 02:58:39 PM
Briggs and Stratton 6 HP OHC Need Help! gohuge Small Air Cooled Gasoline Engines 4 02-11-2009 04:57:39 PM
Briggs & Stratton 5S Engine No Spark whargrov Small Air Cooled Gasoline Engines 19 01-09-2009 10:47:03 PM
Briggs and Stratton 60102 no spark? buddy m Garden Tractors / Mowers / Scooters 4 04-19-2008 10:16:27 PM
Briggs & Stratton Ipfnd Small Air Cooled Gasoline Engines 1 08-04-2005 03:54:02 PM
