Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Can Anyone ID this flywheel engine?
Can anyone ID this engine? Has a two part base, grey paint on flywheels, no tag, small cast...
this thread has 4 replies and has been viewed 861 times
Old 03-29-2009, 12:26 PM
Ray T Ray T is offline
Default Can Anyone ID this flywheel engine?
Can anyone ID this engine? Has a two part base, grey paint on flywheels, no tag, small cast crankguard, slight taper to water hopper, looks to be about 1.5hp? Looks Similiar to Lauson???? Thanks.
Old 03-29-2009, 02:08 PM
Heller D. Davis Heller D. Davis is offline
Default Re: Can Anyone ID this flywheel engine???
Engine is Nelson Bros:
Old 03-29-2009, 07:42 PM
Thanks for info.
Old 05-09-2009, 04:59 PM
Rod Pletan Rod Pletan is offline
Looks just like my Sattley 2hp 500rpm serial no 4892.
Old 05-10-2009, 09:30 AM
Bill Decker's Avatar
Bill Decker Bill Decker is offline
Definitely a Nelson Bros. but, to me, it looks more like a Little Jumbo type engine (Model U?) with the way the mixer come out the side, the position of the gov. weights and the fact that it has grease cups. Also the fact that it has the bracket that bolts onto the side of the head for the plug. My 1 1/2 Sattley doesn't have grease cups, instead, it has the little oil wells, and the gov weights, look more like little half moons, are located in front of the cam gear just behind the flywheel. And the plug is located on the front of the head just above the rocker arm. My 2 cents for what it's worth.
The deterioration of every government begins with the decay of the principles on which it was founded - C. L. De Montesquieu
Flywheel engine on CMT video Terry Beasley Antique Gas Engine Discussion 4 02-07-2009 09:09 PM
Help identify flywheel engine... smgussey Antique Gas Engine Discussion 8 03-19-2008 05:23 PM
Kubota flywheel engine? Patrick McNallen Antique Gas Engine Discussion 5 11-17-2007 01:59 PM
History of a Flywheel engine Sky Antique Gas Engine Discussion 4 09-19-2005 09:49 PM
who built last flywheel engine? Bill Schaller Antique Engine Archives 11 10-23-2002 09:43 PM
