Onan 3.0AJ-1R Parts and information
Hi, I have an Onan 3.0AJ-1R/16017S Serial number J820637165, that was given to me. I was told by...
this thread has 33 replies and has been viewed 4421 times
Old 03-29-2009, 07:35 PM
JRS JRS is offline
Question Onan 3.0AJ-1R Parts and information
Hi,
I have an Onan 3.0AJ-1R/16017S Serial number J820637165, that was given to me. I was told by the previous owner that it runs but it was hard to get it to turn over. I found that the Springs on the DC brushed were melted and the brushes stuck in their channels. I was able to get them out but I am having trouble finding parts or even part numbers for that matter! Any help would be greatly appreciated. Thanks,
Jeff
Old 03-29-2009, 08:57 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Onan 3.0AJ-1R Parts and information
Jeff, Pm "Me" an eMail address that can accept LARGE Attachments and I can send you the Operators & Parts Manual for your Genset.
Bruce in alaska
Old 03-30-2009, 01:54 PM
Gary Potts Gary Potts is offline
Default Re: Onan 3.0AJ-1R Parts and information
I have one DC brush in stock and can get others.
Gary
Old 03-30-2009, 02:45 PM
JRS JRS is offline
Gary,
The DC brushes I need are the Exciter/Starter brushes. Is that what you have? If it is how much are you asking. I would need 2 of them. Thanks,
Jeff
Old 04-02-2009, 11:46 AM
Please send me your E-Mail address, I do not want to get into trouble by breaking rules.
Gary power2rhino@yahoo.com
Old 02-05-2010, 08:52 AM
jeremywilliams jeremywilliams is offline
I am in need of parts and manuals also can anyone email them to me at Smithlakeinc@yahoo.com Thanks
Old 03-22-2010, 10:15 PM
greenfieldmechanical greenfieldmechanical is offline
Please can someone email this info also to: ngreenfield4@sbcglobal.net. Thanks for all the help!
Old 06-23-2011, 04:40 PM
Bobabel Bobabel is offline
I have the Onan 3.0AJ-1R/16017S I also need the Service manual/Parts manual for it, I am having issues getting it to start, sometimes it does most time just clicks. changed silonoid no help but some parts manuals and service manuals would help a lot.. email to bobabel06@yahoo.com
thanks
Old 06-23-2011, 05:12 PM
Service & parts manuals should be in your box. Start with the simple things. "Good" fully charged battery, the bigger the better. Good cables with clean connections, no jumper cables.
The manuals will get you started, the "Smart Guys" here at the Stack will do the rest if you just ask.
Post the Ser. # for better answers.
The Following User Says Thank You to Max Thompson:
Old 06-29-2011, 11:29 PM
jake3277 jake3277 is offline
Max,
I am also the owner of an Onan 3.0AJ-1R, and without any manual. I found this link
and see it is a very fresh article thread, and I was hoping it was still active.
I would greatly appreciate any service and parts manuals that you could send to me.
It runs fine, but on Sunday, when I was running the air conditioning and charging up
my laptop computer, the 110 AC voltage just quit. I don't know if the 2-12volt storage
batteries are getting charged, but that isn't the point.
I need to start at troubleshooting basic, and am a little rusty (I was a an American car mechanic in the early 1970's), so any manuals would hopefully give me clues as to the breakers and fuses that may be associated with this ONAN.
It is in my Winnebago motorhome, which I live in, so it's important to have the generator,
as my solar panels won't run the Air Con. Heh.
Anyway, I hope you see my post.
Jake in Seattle.
Old 06-30-2011, 12:02 AM
mrmegoo mrmegoo is offline
Jake, PM or post your email address & I or someone will send you the manuals you need.
The Following User Says Thank You to mrmegoo:
Old 07-01-2011, 11:03 AM
Hi.
Thanks for replying. I just logged in to put an update with my Email,,,,
as I realized that I did not post it ( I thought it would be readily available, but remembered
everyone else had added theirs).
Email = jakeoem@hotmail.com
Thank you very much!
Old 07-05-2011, 01:20 AM
shybear shybear is offline
I just purchased a motorhome with an Onan 3.0 AJ-R onboard generator. Would also like to get hold of the service manual for this unit. After much tinkering, was able to get the generator started but am not getting AC out of it. Am thinking the problem is with the brushes but am a bit stumped as to how to proceed. I have an owner's manual and it's helped but a service manual might just be the ticket. My email is gdecker@shybearfarm.net if someone out there would be so kind as to send one my way. It would be greatly appreciated!
Old 07-05-2011, 07:32 AM
Should be in your in box.
Old 07-05-2011, 09:08 AM
Jake the manuals should be in your inbox.
Old 07-28-2011, 08:59 PM
quick1956 quick1956 is offline
I am also in need of a manual & parts list for this generator. Thank You in Advance for your Time Percy @ ppcycle@bellsouth.net
Old 07-28-2011, 10:44 PM
Percy, check you inbox. Should be the manuals you need.
Old 08-29-2011, 09:10 PM
themechanic themechanic is offline
hi i have recently just aqcuired a motorhome with an onan 3.0 aj-1r/16018s generator and i have no manuals of any kind would anyone be kind enough to email me the manual or manuals for this model i would be greatly appreciated thanks. chuck_j2010@comcast.net
Old 08-29-2011, 11:26 PM
Check you inbox, should be the manuals you requested.
Old 09-16-2011, 09:35 PM
Praetorian Praetorian is offline
I recently got an Onan 3.0 AJ-1R/16017S Serial G8105882035. It runs and makes power but the intake manifold has one bolt ear broken where it bolts to the block. Could someone pm/email me parts/owner manual for this old boy. Also, any idea what year it might be..
If someone has an intake manifold available, please pm me.
Thank you in advance.
Wayne
Ingeco information and parts help Matthew Sopher Antique Gas Engine Discussion 0 03-12-2009 09:33 PM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07 AM
Need Parts And Mag Information for Stover DV2 edurand Antique Engine Archives 1 01-04-2004 12:10 PM
Alamo Information and Parts Ernest B. Parry Antique Engine Archives 2 11-03-2002 03:27 PM
