Lauson RSC 514-4I have an aluminum block Lauson 514-4 engine that runs a Stewart Warner 782 Aircraft heater, The...this thread has 2 replies and has been viewed 356 times
I have an aluminum block Lauson 514-4 engine that runs a Stewart Warner 782 Aircraft heater, The engine has no spark and I would like to know if parts are available or does any one want it
The Lauson RSC is a very common engine, and most RSC parts are interchangeable. You see a lot of Stewart Warner Lauson parts on eBay from time to time also, so you could probably get the engine running again if you choose to. You may just need to clean it's points. Most of the Lausons I get just need minor work to get them running.
Is the engine on the Stewart Warner heater ? Could you post some pictures. I’ve never seen one and have wondered what they look like. Thanks
Craig Small Engine Collection: http://www.smokstak.com/gallery/browseimages.php?c=108 Last edited by Craig DeShong; 03-30-2009 at 05:52 PM. |
Lauson RSC 514-4 pictures and Stewart Warner 782 heater ( from a Canso I think. It needs a X3404D coil and then it would run.
The devices are Stewart-Warner Southwind Portable Heating Units, Model 782. They embrace (a) a Lauson R. S. C., ball bearing, air cooled, 1˝ H.P., one cylinder, 4-cycle internal combustion engine, with attached magneto; (b) a Stewart-Warner Heater, combustion type, with over-heat switch and Champion spark plug, and (c) a special super-charger, turbine-type blower. Each device functions as a unit. The internal combustion engine must first be started. It then drives the magneto which supplies electricity to the spark plug on the Stewart-Warner Heater to cause combustion of gasoline in the latter, which combustion is the source of heat produced by the unit, and it drives the turbine-type blower so that the latter forces the hot air out of the heater, into three ducts connected with hoses or tubes by which the heat is conducted to the place of use. |
| C.P.&J. Lauson, Christensen or Lauson-Lawton? | Denis Rouleau | Antique Gas Engine Discussion | 9 | 01-31-2009 05:17 PM |
| Lauson TLM | mike83 | Small Air Cooled Gasoline Engines | 5 | 10-20-2008 12:15 PM |
| Lauson 1.5hp H&M help... | Hit and Miss kid | Antique Gas Engine Discussion | 31 | 04-29-2008 01:49 PM |
| Lauson | Tony G | Small Air Cooled Gasoline Engines | 1 | 08-27-2005 12:55 PM |
| CP&J.Lauson,Christensen,Lauson-Lawton | Denis Rouleau | Antique Engine Archives | 0 | 10-21-2000 10:08 PM |
