Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
1948 Briggs and Stratton NS
I picked this Briggs NS up at the Brookville Indiana Swap meet yesterday for almost no money. I was...
this thread has 5 replies and has been viewed 535 times
Old 04-05-2009, 04:39 PM
Jimmy's Avatar
Jimmy Jimmy is offline
Images: 52
Default 1948 Briggs and Stratton NS
I picked this Briggs NS up at the Brookville Indiana Swap meet yesterday for almost no money. I was thriled. It had no compression or spark, but a set of cleaned points and some oil down the cylinder later, it started and ran great.
Here it is:
Old 04-05-2009, 05:42 PM
Arlie Levy Arlie Levy is offline
Default Re: 1948 Briggs and Stratton NS
It looks more like a WI then anything else. I think it has the wrong tag on it. Arlie
Old 04-05-2009, 06:07 PM
Jimmy's Avatar
Images: 52
It looks like a NS to me (like a model N with 7 fins on the block and a suction carb).
I thought a WI only had 5 fins on the block.
Old 04-05-2009, 07:54 PM
Scott Wenrich Scott Wenrich is offline
Images: 139
It's an NS.They have 7 fins which yours has.Careful where you put the head bolts.There are 2 long bolts that go on the higher holes on the head.Some ding-a-ling in the past put one in the wrong place on mine and busted one of the fins off the block.I see this quite often on N's,6's,8's etc.
Your engine does run quite nice,Jimmy.It must be well balanced cuz i don't see it mounted to anything!
Scott
Old 05-20-2009, 01:53 PM
RJAaaaaa RJAaaaaa is offline
I'm glad to see some one else uses there table saw for many things, I dread even thinking about cleaning mine off to cut a board! Nice engine.
Old 05-20-2009, 04:23 PM
Jimmy's Avatar
Images: 52
Ha ha most of my videos take place on the table saw. In fact, I don't even remember the last time I used it to cut something...
5 HP briggs & stratton jim cobb Small Air Cooled Gasoline Engines 11 02-07-2009 08:57 PM
1948 Briggs NS Type numbers Dennis Wyatt Small Air Cooled Gasoline Engines 0 01-12-2009 06:39 PM
Briggs & Stratton FH Bill Sherlock Small Air Cooled Gasoline Engines 1 10-08-2006 06:29 PM
Briggs & Stratton Ipfnd Small Air Cooled Gasoline Engines 1 08-04-2005 04:54 PM
Briggs & Stratton WM Lou Quirch Small Air Cooled Gasoline Engines 4 05-16-2005 06:28 PM
