Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Unidentified Verticle gas engine, Any help would be appreciated.
I bought this engine from a friend and don't know anything about it. It came with a pail full of...
this thread has 3 replies and has been viewed 706 times
Old 04-07-2009, 10:48 PM
jd3ep jd3ep is offline
Default Unidentified Verticle gas engine, Any help would be appreciated.
I bought this engine from a friend and don't know anything about it. It came with a pail full of parts and all the other things you see in the pictures. It has alot of original green paint on it. There are no names anywhere, only a couple numbers in the casting, and those are really hard to make out. It appears to be a two cycle engine as the intake goes right into the main bearing. If anyone might know something on this engine, please let me know. The flywheels are about 18" diameter.
ID:	51842   Click image for larger version
ID:	51843   Click image for larger version
ID:	51844   Click image for larger version
The Following 2 Users Say Thank You to jd3ep:
Old 04-08-2009, 08:11 AM
Rich Hudak Rich Hudak is offline
Default Re: Unidentified Verticle gas engine, Any help would be appreciated.
Just a thought, aren't those 1hp Gray/Caille flywheels?
The Following User Says Thank You to Rich Hudak:
Old 04-08-2009, 12:56 PM
Daniel Dorece's Avatar
Daniel Dorece Daniel Dorece is offline
I agree with Rich. A Gray, Caille or Termaat & Monahan from the looks of the flywheels.
Iron Wolf
The Following User Says Thank You to Daniel Dorece:
Old 04-09-2009, 10:21 PM
Thanks for the info, Do you guys know where I can find out more about that line of engines? I would like to know the age of it and if they are common engines or rare.
Help ID a verticle steam engine? Doug Waggonner Stationary Steam & Traction Engines 5 03-02-2009 08:37 PM
Need help to identify this verticle hit and miss engine Gordon Green Antique Gas Engine Discussion 0 06-17-2008 08:59 PM
Wico EK Help Appreciated Mike Cannon Magnetos, Ignition Coils and Spark Plugs 1 12-31-2007 07:52 PM
Maytag 92, help appreciated! JimS Maytag Engine Collectibles 2 07-24-2006 05:23 PM
small verticle steam engine Tom Winland Stationary Steam & Traction Engines 3 02-01-2004 12:32 AM
