John Deere power unitdose anyone know the hp of a jd powerunit it is a model luc the ser # c 57435 , it has a wico mag ,...this thread has 5 replies and has been viewed 780 times
dose anyone know the hp of a jd powerunit it is a model luc the ser # c 57435 , it has a wico mag , crank start , clutch,transmison and big pulley on back with a shaft comeing from the transmison to the front with a sprocket on it , water cooled radiator with a big screen over it . what were these mainley used for. it runs good and starts easy. ron brown in central illinois
Number one use: 12A combines. There are also other versions of the L power units. The LUC is still quite common. We had 2 of them around here when I was a boy. Still have one.
I looked around and it seems that the LUC had about 16hp at the crank.
good luck, I want one some day. Bryon |
I have one . And have had several that I have sold. They are rated 14 hp and 16 hp max. These engines run good just be careful cranking it as they have a habit of kicking. I have a manual if you need more specs.
Nathan
www.nathansoldiron.blogspot.com |
Had an LUC and two JD L tractors (still have a 1943 model).
They don't kick if the mag is correctly set.......
http://www.youtube.com/cahartley7 |
thankd guys i was wondering about the hp , any ideal where i can find the date of mfg. thanks again ron brown in central illinois
| John Deere Model # 809 drive unit | Bob Johnson | Antique Gas Engine Discussion | 1 | 03-17-2009 01:23 PM |
| John Deere 70 power blocks | nrffarmboy | Antique Tractor Talk | 3 | 03-05-2009 05:39 PM |
| John Deere Power unit | Bob Ronning | Generators & Motors General Discussion | 14 | 12-06-2007 09:25 AM |
| John Deere LU Power Units | Scrap Iron | Antique Tractor Talk | 4 | 10-20-2007 03:04 AM |
| John Deere Model LUC power unit | Tom weatherford | Antique Engine Archives | 0 | 06-06-2004 09:11 PM |
