Source For 1/2" pitch Chain
Hi, I have a David Bradley model 91760029 that I want to get back into running condition (was...
this thread has 4 replies and has been viewed 575 times
Old 04-14-2009, 12:19 PM
matthewblckwd matthewblckwd is offline
Default Source For 1/2" pitch Chain
Hi,
I have a David Bradley model 91760029 that I want to get back into running condition (was running when it was stored many years ago) and use it on a chainsaw mill, and I am looking for either a source for 1/2" pitch chain or to find out if it is possible to put a modern bar and chain on it.Thanks for any help!
Matthew
Old 04-14-2009, 02:35 PM
Default Re: Source For 1/2" pitch Chain
I saw some 1/2" chain listed on ebay under Clinton chain saws that would probably work. Pretty pricey stuff though!
Bill
Old 04-14-2009, 11:20 PM
John in Maryland's Avatar
John in Maryland John in Maryland is offline
My local True Value will make up chains for different saws. Don't know if they sell 1/2 or not.
M.D.
Old 04-15-2009, 12:05 AM
Sven Johnson Sven Johnson is offline
I have some new 1/2" pitch 063 gauge chain. If you are interested e-mail me
----hotsaw@ct.metrocast.net-------
Sven.
Old 04-15-2009, 02:01 PM
sawcollector sawcollector is offline
Matt, I am sorry to be so negative but you will spend more on the chain than a new saw, and an old DB gear drive ( I assume) will be very slow on a mill. Unless you have done it before or know something I don't.
On the other hand I agree that sometimes we have to use what we have to get the job done, and there is nothing wrong with that either. If you get it going we need pictures!!!
1-1/4" whistle valve source? Allen Stationary Steam & Traction Engines 4 08-01-2008 08:16 PM
Need source for 3/4" NPT Try-cocks tirediron Stationary Steam & Traction Engines 6 09-08-2006 12:49 AM
Source for new 1 3/4" boiler tubes David Stationary Steam & Traction Engines 4 05-03-2006 10:30 AM
Pick "em up" with a chain thru the flywheels? Gene Fisher Antique Gas Engine Discussion 19 04-09-2006 08:30 PM
Here is a good source for FM "ZC" parts AND late model Witte parts Doug Waggonner Oil Field Engines 2 09-13-2005 10:40 AM
