Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Galloway serial number.
Just pick up an 2 1/2 or 3 HP Galloway with no tag. Serial number is 89462. Anybody have a good...
this thread has 7 replies and has been viewed 413 times
Old 04-18-2009, 08:35 PM
Frank OMeara Frank OMeara is offline
Default Galloway serial number.
Just pick up an 2 1/2 or 3 HP Galloway with no tag. Serial number is 89462. Anybody have a good list. I found several on the web but none that goes up very high. Sure would like to know when this engine was made. Thanks Frank
Old 04-18-2009, 09:53 PM
Randy Wells's Avatar
Randy Wells Randy Wells is offline
Default Re: Galloway serial number.
Hi Frank. That is an incredibly high serial number. With no tag where did you locate this number? Can you take a picture of it for me? Could the number be 36942? I am an avid Galloway collector and have a pretty good source for the serial numbers. Galloways are fantastic engines to have.
Randy
Old 04-18-2009, 11:13 PM
oldironcollector's Avatar
oldironcollector oldironcollector is offline
+1 on that high serial number. Does it have a mag on it? if so is it a Webster or Wico?
Denny
Old 04-19-2009, 11:19 AM
Hi Randy: I got the ser number off the end of the crankshaft. The number was covered with a lot of rust. Will check again and get back with you, my eyes are not like they used to be. It has a Webster mag on it. Thanks for help. Frank
Old 04-19-2009, 11:31 AM
Hi Denny: It has a Webster on it. Will check the ser number agin. From the pictures on the net it looks like Bulldog model with the rounded rectangle water tank top. The number was stamped on the end of crank. Is there another location! Thanks Frank
Old 04-20-2009, 04:05 PM
Hi Randy found another ser number on the other end of the crankshaft and it was clear. 39463. By the list that I have it makes it a 1917 or 1918 model I think, thanks for the help Frank
Old 04-20-2009, 04:08 PM
I found a clear ser number on the other end of the crank. 39463. Thanks for the help Frank
Old 05-05-2009, 12:37 AM
Joseph Cissell Joseph Cissell is offline
Randy, Would you send me a email or your phone number, as I would like to talk to you about Galloway engines. Thank you, Joe A
Associated Serial Number David Cave Antique Gas Engine Discussion 3 02-20-2009 07:53 AM
Serial number help Kevin Currie Antique Gas Engine Discussion 5 09-28-2008 01:20 PM
Associated serial number????? Gene Fisher Antique Gas Engine Discussion 2 06-05-2007 09:23 PM
galloway serial number location Tim Rostar Antique Gas Engine Discussion 1 07-23-2006 07:37 PM
Galloway Serial Number Plate Bob Johnson Antique Engine Archives 9 11-22-2004 07:44 PM
