Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Specifications for a 12hp Kohler engine?
this thread has 5 replies and has been viewed 10826 times
Old 04-20-2009, 01:46:04 PM
gruby26 gruby26 is offline
Default Specifications for a 12hp Kohler engine?
I working on rebuilding a 12 hp kohler and i was wondering if anyone had the torque specs and valve lash.
the model # is K301a
and the spec# is 47446b
thanks for any help
Old 04-20-2009, 02:52:08 PM
Mike in NC's Avatar
Images: 63
Default Re: specs for a 12hp kohler?
Try this link to the K-Series Service Manual
The Following 2 Users Say Thank You to Mike in NC For This Post:
Old 04-21-2009, 12:31:46 AM
Skippy1969 Skippy1969 is offline
Default Re: Specs for a 12hp Kohler?
thanks for any help
Here you go,right from the official Kohler manual.
Head bolt torque = 25-30 ft lbs.
Rod bolt torque
Posi lock New service rod= 260 in lbs.
Posi lock Used/reinstalled rod= 200 in lbs.
Cap screw New service rod= 285 in lbs.
Cap screws Used/reinstalled rod= 285 in lbs.
Valve clearance
Intake .008" - 010"
Exhaust .017"-.019"
Piston ring end gap
New rings .010"-.020"
Used rings .010"-.030"
Flywheel nut 50-60 Ft. Lbs.
Flywheel bolt 22-27 Ft.Lbs.
If you need any other specs let me know.
The Following User Says Thank You to Skippy1969 For This Post:
Old 04-21-2009, 02:11:28 AM
thanks for the help thats just what i needed
Old 04-21-2009, 08:56:33 AM
K D Redd K D Redd is offline
BE SURE when you set the exhaust valve clearance you have the piston AT or a little after TDC at the end of the compression stroke/start of the power stroke. This will make sure the decompression release is not holding the exhaust valve lifter up which can cause a INCORRECT exhaust valve clearance setting. I like to set the valves BEFORE I install the head. Then I can turn the engine through and watch to make sure the exhaust valve is bumped off it's seat when the piston is about halfway up the compression stroke. This only happen at low starting speeds. When the engine comes to speed the decompression function stops.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 04-21-2009, 10:39:39 AM
Default Re: Specifications for a 12hp Kohler engine?
thanks for the tip ill have to wch out for that
Torque specifications gruby26 Small Air Cooled Gasoline Engines 6 01-17-2009 12:35:09 PM
12hp ELLIS engine Oilpullman Antique Gas Engine Discussion 8 03-26-2008 04:43:10 PM
Kohler Air-Cooled Engine Specifications ListerDiesel Small Air Cooled Gasoline Engines 1 07-30-2007 03:53:29 AM
Hercules piston specifications Mike D1 Antique Gas Engine Discussion 0 08-29-2005 09:04:08 AM
12hp Fairbanks/Morse engine mastermind1188 Antique Engine Archives 4 08-12-2004 03:40:52 PM
