Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
New member Alllis Chalmers question
Hello All I found this forum in a Google search for Alllis-Chalmers. I do HO scale model...
this thread has 4 replies and has been viewed 528 times
Old 04-21-2009, 11:08 AM
lexon lexon is offline
Default New member Alllis Chalmers question
Hello All
I do HO scale model railroading and I am building a model of this flat car. The car and load are outside a Allis-Chalmers factory in 1901.
I was told by someone, the crank shaft is for a Hamilton-Corliss steam engine.
I have done a lot of searching for hamilton coreless, allis chalmers steam engines and found a lot of data concerning huge stationary steam engines.
Anyone have any idea of the use for a crank shaft this size? Steam engine, pump, hot air blower for a steel mill of the era?
Thanks.
Rich
Old 04-21-2009, 09:38 PM
todengine's Avatar
todengine todengine is offline
Default Re: New member Alllis-Chalmers question
Hey! I've got one of those crankshafts!
http://www.todengine.org/
Old 04-22-2009, 02:33 PM
Default Re: New member Alllis Chalmers question
Thanks, that crankshaft looks much like the one on the flat car.
lexon
Old 04-22-2009, 03:24 PM
survivingworldsteam's Avatar
survivingworldsteam survivingworldsteam is offline
Email Not Working
As Rick pointed out; definitely a steam engine, and a large cross compound one. Allis Chamlers was most famous for building steam pumping engines; so if I had to harzard a guess; I would say a cross compound steam pumping engine or air compressor; this is a pair of pumping engines still in a pump station in Waco; Texas.
-James Hefner
Hebrews 10:20a
Old 04-28-2009, 10:24 PM
todengine's Avatar
Because there are no return cranks or generator rotor on the crankshaft, my guess is that it was for a cross compound blast furnace blowing engine, most likely a horizontal as they were most common.
Allis Chalmers mag question Mike Monnier Antique Tractor Talk 3 06-02-2009 12:56 PM
New member with a 4.0 CCK 1R kickboxer1961 Onan Generators 7 12-09-2008 09:01 PM
new member FirstEliminator Antique Gas Engine Discussion 9 12-27-2006 01:14 PM
New Member Pete LaBelle Stationary Steam & Traction Engines 6 02-09-2006 02:41 AM
Allic chalmers [G] question Ihorse Antique Tractor Talk 4 06-12-2005 12:27 AM
