Strunk Lives!Well, after a hibernation of approximately 4 years, I fired up the old Strunk yesterday. I just...this thread has 8 replies and has been viewed 1017 times
Well, after a hibernation of approximately 4 years, I fired up the old Strunk yesterday. I just added some newer old gas to the mystery mixture in the tank, set the choke and after around 10 pulls, she fired. A few more times and she ran on her own. Heavy, loud as hell and had almost every neighbor looking out their windows to see what monster had been unleashed upon the earth. Just me and my Strunk. Included a couple shots of the star attraction.
Nice Strunk. One year I will get ours out and running.
Mike Murphy Mike & Jen's Old Engines |
Nice saw! I haven't had mine out in about 10 years. It is painted red and I believe it is a "big timber" model. I don't know about the rest of the Strunk line up but mine mixes the oil and the gas by itself. It's the only saw I have like that. While it is loud, I've got a Clinton and a Wright that are worse. I learned many years ago NOT to crank these things up even for a moment inside the shop!
Hi
strunk chainsaws are cool.I have a pro timber 38 lbs. Cant figure throttle linkage [have parts] can anyone help? instructions or close up picture or diagram. I have 5 tillotson carbs,7ral bars and chains and 2.lg malls |
how old is this saw?
The saw is around 1956-1957 era.
just wondering how rare a Strunk is? Ive got two, one complete and the other is now powering a kids tricycle. mine seems to be differnt than yours my gas tanks are more streamlined than yours. Does this give you any idea of a year? Any help would be great. Thanks, Dudley
Fyi..........
Alain, www.vintagechainsawcollection.blogspot.com This is a Strunk Model "MORWOOD" direct drive.....same as the Speed Cut. Model: MORWOOD DIRECT DRIVE MANUFACTURED BY:STRUNK MANUFACTURING CO. COATESVILLE, PENNSYLVANIA, U.S.A. YEAR INTRODUCED: 1956 ENGINE DISPLACEMENT: 4.7 cu. in. (77cc) NUMBER OF CYLINDERS: 1 CYLINDER BORE: 2.0 in. (50.8 mm) PISTON STROKE: 1.5 in. (38 mm) CYLINDER TYPE: Aluminum with cast iron sleeve INTAKE METHOD: Reed valve MANUFACTURER ADVERTISED H.P.: 3.5 WEIGHT : 21 lbs. (9.5 kg) powerhead only OPERATOR CONFIGURATION: One Man operation HANDLEBAR SYSTEM: Rigid CHAIN BRAKE: none CLUTCH: Centrifugal DRIVE TYPE: Direct CONSTRUCTION: Sand cast aluminum MAGNETO TYPE: Wico FW2288 CARBURETOR: Tillotson HP-12A AIR FILTER SYSTEM: Skinner ribbon element STARTER TYPE: Fairbanks Morse automatic rewind OIL PUMP: Manual OPERATING RPM: 4,500 IGNITION TIMING: 0.175 in. (4.44 mm) before TDC BREAKER POINT SETTING: 0.020 in. (0.51 mm) FLYWHEEL/COIL AIR GAP: Position is fixed SPARK PLUG TYPE: Champion J8J, Autolite A7X, AC M45 SPARK PLUG GAP: 0.030 in. (0.76 mm) CRANKSHAFT MAIN BEARINGS: Ball FUEL OIL RATIO: 1/2 pint to 1 gallon = 16:1 RECOMMENDED FUEL OCTANE: Regular grade 72 to 83 MIX OIL SPECIFICATION: SAE 30 non-detergent motor oil CHAIN PITCH: 1/2 in. CHAIN TYPE: Atkins SHORTEST GUIDE BAR SUPPLIED: 16 in. (40 cm) LONGEST GUIDE BAR SUPPLIED: 19 in. (48 cm) COLOUR SCHEME: Grey enamel |
It is using a Power Product(Tecumseh) Type AH 47( 4.7 CU-INCH).....Mainly a re-badge saw copied and mass produced.
Alain, |
| It Lives!! Thanks everyone! | Mbrgr | Onan Generators | 13 | 02-26-2008 07:22 AM |
| 5 CCK, It Lives !!! | Mat Phelps | Onan Generators | 0 | 01-12-2007 09:20 PM |
| The 6 'M' Lives | Tim Claremont | Antique Gas Engine Discussion | 2 | 08-25-2006 09:13 PM |
| Another one lives | Sky | Antique Gas Engine Discussion | 4 | 05-29-2006 10:49 PM |
| Another One Lives | Dustin D Ehli | Antique Gas Engine Discussion | 0 | 05-07-2006 10:06 PM |
