| Onan Generators Restoring, operating and maintaining vintage Onan generators. |
ONAN Power Unit PE-95-GHello all, just found this site....and its a great one!!!! I just bought this unit.. ONAN Power...this thread has 5 replies and has been viewed 902 times
I just bought this unit.. ONAN Power Unit PE-95-G Serial #19 Order #10711-Phila-44 Pictures: http://s224.photobucket.com/albums/d...n%20Generator/ It even runs........but looking for a manual/info/etc...anything downloadable??? Any ideas on what this may be worth, cleaned and tuned up??? B.Gill, bgill@wecon.com |
These units seem to be popping up all over the place lately.
The service manual is TM11-904 and is available for download in .pdf format at: www.ronfoo.com/generator.html This manual covers PE-95A through PE-95H models. |
The Following User Says Thank You to Kevin K:
What is your engine serial number? (example MB-333333) It is located on a raised boss behind the oil filter canister or on a boss on the block/head area right behind the water pump. Some characteristics of your unit seem later than a "G" unit. Rich
The Following User Says Thank You to Rich Mc:
I will get the engine serial numbers tonight....from an earlier "look" the numbers did indicate a WW2 Willys engine.
Would that be a CJ2A hooked to your gen? What year is it?
I owned a PE-95 about 30+ years ago. I never had (nor needed) a manual for it because all I ever had to do was change the oil and keep a good battery in it.
In a world where gasoline cost less than 50 cents a gallon, it was a great generator. Vaughn |
| IH U21 power unit | Tinker Moats | Antique Gas Engine Discussion | 5 | 08-24-2008 05:50 PM |
| PE-95-K Power Unit | Mike D'Antonio | Generators & Motors General Discussion | 2 | 11-01-2005 09:03 PM |
| Le Roi Power unit | Marty | Antique Engine Archives | 2 | 08-02-2003 04:40 PM |
| BSA Power Unit | David Hagan | Antique Engine Archives | 3 | 09-10-2002 09:01 PM |
| IHC POWER UNIT | PETE | Antique Engine Archives | 0 | 12-10-2000 12:16 AM |
