Troy-bilt 7550 voltage problems
Hello, I have a Troy-Bilt 7550 Model #01925. Yesterday i used it and found out it's only...
this thread has 2 replies and has been viewed 511 times
Old 05-04-2009, 09:00 AM
jasonp jasonp is offline
Default Troy-bilt 7550 voltage problems
Hello,
I have a Troy-Bilt 7550 Model #01925. Yesterday i used it and found out it's only putting out voltage to one leg of the 220 plug and also 2 of the 4 110 plugs. What do u suggest?
Old 05-04-2009, 10:20 AM
Elden DuRand's Avatar
Images: 6
Default Re: Troy-bilt 7550 voltage problems
Jason:
I suspect one of the following things:
- Bad winding
- Bad brush/slipring
- Broken connection between slipring brush and plugs
- Blown fuse or breaker
- Evil spirits
Other than that, I don't have a clue.
Take care - Elden
Old 05-04-2009, 05:22 PM
Are these test hard? where do you suggest i start? Fuse is fine. Breakers are fine.
Onan 30EK-4R871K Voltage Problems James178 Onan Generators 13 04-16-2009 05:24 PM
79 Troy Bilt horse engine replacement? Hans Seyerle Garden Tractors / Mowers / Scooters 0 04-06-2009 02:42 PM
Troy Bilt Wheel Horse help GLF4 Garden Tractors / Mowers / Scooters 2 03-30-2009 06:19 PM
Generac voltage problems kphee Generac Generators (SEARS, etc.) 6 12-09-2008 12:57 AM
voltage problems charliej Kohler Generators 1 08-05-2006 11:16 PM
