Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Horse Drawn Equipment
What in the world is this?
I purchased this item from my uncle, but do not have an idea what it was used for. I can tell that...
this thread has 6 replies and has been viewed 1123 times
Old 05-04-2009, 04:33 PM
hisind69rsss hisind69rsss is offline
Default What in the world is this?
I purchased this item from my uncle, but do not have an idea what it was used for. I can tell that it was probably drawn by a horse or mule. It appears to be some kind od grinder. Also I am thinking that a "hopper" should be with this unit for feeding it.
If you have any info I would be greatly appreciative. I can not find any name or model number on it.
Thanks, John
Name:	Grinding Mill 001.jpg
ID:	53696   Click image for larger version
Name:	Grinding Mill 004.jpg
The Following User Says Thank You to hisind69rsss:
Old 05-04-2009, 05:43 PM
Keith Kinney's Avatar
Keith Kinney Keith Kinney is offline
Default Re: What in the World is This
I'd say it is some sort of horse powered feed grinder. Take a look at this web page. Maybe something like the #19??
http://www.oldengine.org/members/sba...epartslist.htm
Keith
Keith Kinney
www.HerculesEngines.com
The Following User Says Thank You to Keith Kinney:
Old 05-04-2009, 06:22 PM
Neal in Alabama Neal in Alabama is offline
Check out this post...http://www.smokstak.com/forum/showthread.php?t=59033
The Following User Says Thank You to Neal in Alabama:
Old 05-06-2009, 05:14 AM
Wayne Riedlinger Wayne Riedlinger is offline
We have one in the museum that looks the same. Ours is a Stover, I was told that it was used to grind up coal to be used in stoker furnaces. I have seen almost the same machine for grinding grain or corn for feed but the grinders inside are much different.
The Following User Says Thank You to Wayne Riedlinger:
Old 05-08-2009, 02:26 PM
Thanks for your info. I have yet to check out the sites mentioned but will do so soon.
Regards, John
Old 05-08-2009, 02:39 PM
Wayne,
Thanks for the information. You mentioned that you had a picture of your Stover unit. Would you mind sending me a picture of it if it is not too much bother. My email address is hutchersonsupply@bellsouth.net.
Regards, John
Old 05-08-2009, 02:59 PM
Yes I can but it will be a while. I wont get back home for a month or so. (away working).
Medina of MY world... James Maxwell Stationary Steam & Traction Engines 5 12-13-2007 11:07 AM
Its a Mad Mad Mad Mad World Motormowers Small Air Cooled Gasoline Engines 17 07-24-2007 01:21 AM
Greatest job in the world Frank DeWitt Stationary Steam & Traction Engines 0 06-06-2007 04:18 PM
Disney World Engines? David Swa nson Antique Engine Archives 11 01-30-2004 10:53 PM
What has the world come to Steve Gerot Antique Engine Archives 5 05-22-2002 11:09 PM
