Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Horse Drawn Equipment
Can someone help me ID this plow?
http://www.dbc3.com/images/plow.html No nameplate anywhere. I know I'll not figure out the...
this thread has 11 replies and has been viewed 956 times
Old 05-08-2009, 08:11 PM
dbc3 dbc3 is offline
Default Can someone help me ID this plow?
I know I'll not figure out the manufacturer, but would at least like a guess at the age and probable usage.
Old 05-08-2009, 11:35 PM
Keith Thomas Keith Thomas is offline
Default Re: Can someone help me ID this plow?
That is commonly called a potato plow and used to turn out potatoes or break loose ground for any other need. Age could be pre-1880-1945
Looks like it's time to start cut'n spuds and plant'n.
Keith
The Following User Says Thank You to Keith Thomas:
Old 05-09-2009, 09:15 AM
Thanks! I had the use fairly well guessed from the design. Of course 1945 is not all THAT recent, but it did seem to be styled from an earlier era. I can tell myself it is 'way older (although the condition of the wood might put that in doubt). I guess they still used a wood beam and light construction like this that recently since they didn't need the strength (and cost) of steel for the intended use.
Regardless, it is my first "find" and will have a place of honor in my hoped-for collection-to-be.
Old 05-09-2009, 11:01 AM
mschreiber mschreiber is offline
i call it a shovel plow. if its kinda on the wide side it'll be for potatoes like referenced. i got a coulple narrower ones, one stamped on the backside of the shovel reads, "blount true blue". i'd clean it up, you may find it marked.
good luck.
Old 05-09-2009, 02:57 PM
Farquhar Farquhar is offline
Here in the mtns. we called that a "Bull Tongue" plow.
Used to lay off a row for planting, and of course to dig "taters". The one we have here had a smaller point on it than the one pictured. Yours was probably used, with the wide point, for digging root crops.
Old 05-10-2009, 12:50 PM
Does this look like my missing part?
Old 05-10-2009, 01:25 PM
If the depth is right, it would replace the hardware that is on the tongue now and the single tree would attach to the ring.
It is an early piece of hardware and appropriate for the probable age of the plow.
Keith
Old 05-10-2009, 02:25 PM
pictured upside down though.
The Following User Says Thank You to mschreiber:
Old 05-10-2009, 11:22 PM
Right - makes sense -the thumbscrew up. The photo is from someone who found the part in his woods a few weeks ago and was asking if anyone knew what it was. Someone said it went to a potato plow. I am trying to contact the guy.
Old 05-10-2009, 11:34 PM
The hardware on the tongue is incomplete - I've been trying to figure out what was missing. There are two pieces with holes in ends for something - but the hole in the bottom piece of hardware is far too small to take something that would carry the load. I just wired in a piece of black plastic tubing to hold the parts together. From what you say, and the look of this piece, maybe the hardware that is there is just bogus, rather than incomplete. Someone just guessed and put some pieces there?
Old 05-11-2009, 09:50 AM
what's on the plow beam as pictured is bogus to me. the hitch clevis pictured will have at least 2 bolts holding it on. one of them being the wrench.
Old 05-11-2009, 11:54 PM
It is becoming clear to me. I wondered about the description of the clevis' three notches being to adjust the height for depth and/or height of horse - couldn't see why the ring would not just fall when the traces went slack. But now I think I see that the height adjustment would be made with the clevis rotated to the side, and when lined up with the beam, the wooden beam end would trap the ring in the chosen slot - pretty clever design! (assuming I'm right). Tomorrow I'll go look for signs of wear on the wood. And try again to contact the finder of my clevis!
M J.D.plow Roger Kirschenman Antique Tractor Talk 0 04-27-2008 02:37 PM
Looking for JD No. 82 plow ... Still. Bruce B. Antique Tractor Talk 0 04-04-2007 07:55 PM
Looking for JD No. 82 plow ... Still. Bruce B. Farm + Industrial Antiques and Collectibles 0 04-04-2007 07:55 PM
Some plow day pictures Dking(MI) Antique Tractors - Old Iron Lugs, Cleats and Tracks 5 02-15-2007 10:52 AM
one big plow OldAgIron Farm + Industrial Antiques and Collectibles 6 02-28-2006 10:22 PM
