| Vintage Diesel Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines. |
Witte MD 12 Torque SpecsI have a manual but it is rather general. I need torque specs. Does anyone have a manual for a...this thread has 3 replies and has been viewed 933 times
I have a manual but it is rather general. I need torque specs. Does anyone have a manual for a Witte MD 12 with torque specs? Right now I need cam case bolt specs and the flywheel nut specs. I'm sure I'll need more eventually. Thanks
Rick |
Hell Rick,
Hope this helps: Counterweight Stud Nuts------200-210 lbs./ft. Rod Cap--------------------------75-85 lbs./ft. Head Nuts ----------------------180-190 lbs./ft. Flywheel Bolt--------------------170-180 lbs./ft. Flywheel Runout Max----------.020" T.I.R Cam Case Bolts-----------------35-45 lbs./ft. Nozzle Holder Nuts-------------110-130 in./lbs. Crankshaft End Play------------.000"-.004" (Max) David Johnson Witte Mania wittemania@cox.net |
HELLO Rick, sorry for the spelling error.
Witte on the brain......... |
Hi Rick I have one of these witte 12 hp md gens. how much oil does one of these take?
| Petter ac1 torque specs? | jgnat1488 | Vintage Diesel Engines | 9 | 07-30-2012 06:45 PM |
| Need hp/torque/rpm specs for Power Products AH-47 | Mac Leod | Small Air Cooled Gasoline Engines | 0 | 05-30-2008 10:22 PM |
| torque specs | Derek Watt | Antique Tractor Talk | 2 | 08-02-2007 09:24 PM |
| Briggs Torque specs. | john hatc. | Small Air Cooled Gasoline Engines | 3 | 07-15-2006 08:31 PM |
| Torque specs for an Onan | Chip_er | Small Air Cooled Gasoline Engines | 3 | 07-14-2006 10:40 PM |
