Piston RingsAnyone know where I can get a set of rings for my 2HP Sundial? the rings are: 4" x 7/32. Stof ...this thread has 18 replies and has been viewed 749 times
starbolt on the sponsers page
Starbolt dont have 4" x 7/32"
Did you try Otto engine works? he's a sponsor here.
20th Century Machine's http://www.youtube.com/user/VintageClassic1 |
You got access to a lathe Stof? I can run you through how I make mine. Its about the easiest part of a engine restoration.
Hi Ray, yes I have access to a lathe, Please explain?
Stof,get a bit of 3D cast iron from someone like Assab or Bohler or any steel merchant. Chuck in up in your 3 jaw and turn the O.D the same size as your bore diameter.Bore the Inside diameter to the dimension of one of your old rings installed in the bore. Now part the rings off to the dimension of your ring groove less the clearance you want. I make mine the same as the groove and polish with fine emery on a flat surface till they are nice fit in your piston groove. Next split the rings. I just put them in the jaws of a bolt cutter and apply a bit of pressure and they will snap cleanly.Make up a wedge or spacer out of a bit of keysteel or what ever you have and stack your rings together with the spacer holding them open to the gap you want.Sandwich them together between a couple of bits of plate with a 3/8 or whatever bolt you have to keep them nice and flat. Wrap some fireproof material around the outside of the rings to keep the direct heat of them and wire it in place. Make up a little firebrick or whatever you have to keep in the heat furnace and stick a LP torch in there and heat them to a dull red for a couple of hours and let cool out slowly. Take your plates apart and file your gaps to what you want.I've done a number of sets for myself and friends and never had a problem. If your cylinder is good you won't get any leakage. I have also made some out of ordinary scrap cast iron and they have worked good to.
The Following 3 Users Say Thank You to Ray Freeman:
Definitely Tom......besides......the piston grooves are most likely worn anyway.
http://www.youtube.com/cahartley7 |
The Following User Says Thank You to Craig A:
Give JP Pistons a try they are in South Australia they make rings and pistons look up they web site, I have dealt with them found them and found them very helpfull http://www.jp.com.au/JPPistons.html
The Following User Says Thank You to Steve Shearman:
Contact Mary at Niagara Piston works? They do custom piston rings. They did mine for the oversized FBMZ.
L www.engineutopia.com |
Try Don Reid, Vintage Engine Spares in Queensland, he advertises in TOMM and has been very helpful. He has a lot of sizes in stock.
regards Jim |
Hi Jim, I spoke to Don on wednesday, with a good result.
He is sending me a set next week. I am getting a maggy gear of him to. Thanks to all |
Stof....as Ray says if you have a lathe it is easy and once you have made one set you will never buy them .Unlike Ray I use a small electric kiln does the same job as the way Rays uses .I leave it overnight to cool .I also de glaze the bore . Sometimes finding the right size Cast Iron is hard .....I am having that problem at the moment.Iam not as game as Ray ...using bolt cutters ,it is a hacksaw for me!
Hi all ,
I have heard that the makers of rings somehow snap them ,I am not game to try,so use a cut off wheel one of those 2 mm thin ones they do do a quick job and do now make the ring to hot . Rod PS ,I see on this forum one can thank people for their reply,s how do I do that ? |
The Following User Says Thank You to Rod E:
Have a look at the bottom R/H corner of the post. I know you cane toads are a bit backward over there but you can still see![]()
The Following User Says Thank You to Ray Freeman:
Hey us Cane toads are smart I see the button what does it do ?I just pressed it ! we know that only Sandgropers live where the sunsets
regards Rod |
Not to smart Have a look in the top r/h corner of your post![]() And I got cane toad relations that come here to see the sunset over the ocean!
| Piston Ring Material for Custom Machined Piston Rings. | Uncle Old Iron | Antique Gas Engine Discussion | 3 | 06-24-2007 02:50 AM |
| Piston Rings | Mike McKinney | Antique Gas Engine Discussion | 6 | 04-15-2006 07:29 PM |
| Piston Rings | Lonnie Grissom | Antique Gas Engine Discussion | 3 | 03-16-2005 07:25 PM |
| Re: Piston Rings | John Culp | Antique Engine Archives | 8 | 01-09-2001 01:40 AM |
| Piston rings | Ed Jablonski | Antique Engine Archives | 3 | 10-12-2000 10:20 PM |
