Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Toy Steam Engines and Motors
Briggs & Stratton 2. 3 horse?
hello boys i have a briggs & stratton horz 3/4" shaft with a up draft carb on it the con rod is...
this thread has 4 replies and has been viewed 763 times
Old 05-15-2009, 12:22 AM
brian leonew brian leonew is offline
Default Briggs & Stratton 2. 3 horse?
hello boys i have a briggs & stratton horz 3/4" shaft with a up draft carb on it the con rod is shot broke off at the crank there is no shroud on it to tell me the type code or model how can i find the right con rod for it with out the model type & year.. thanks brian
Old 05-15-2009, 12:30 AM
Default Re: briggs & stratton 2. 3 horse???
Photos--photos--photos !
Also, post the bore size and estimate the stroke as the rod is broken. Include photo of the carb. and starting sysyem. (rope, recoil, etc.)
Someone should be able to ID the engine from that info.
Jim
The Following User Says Thank You to Jim Tremble:
Old 05-15-2009, 03:15 PM
Default briggs & stratton 2. 3 horse???
hello i have a briggs with a broken rod i dont think the shroud is the right one the bore size is 2,3/8 piston is 2,5/16 can someone tell me what horse it is and what rod i should get the numbers on the shroud are model 92902 type 0675-02 code 78071912 here are some photos. thanks brian
ID:	54457   Click image for larger version
ID:	54458   Click image for larger version
ID:	54459   Click image for larger version
Old 05-15-2009, 03:35 PM
Tom Kilgore Tom Kilgore is offline
most of the 2 3/8 bore engines used a 294367 briggs rod I don't see a 2 5/16 bore on a briggs the 92900 series is a 2.5625 bore. hope this helped.
The Following User Says Thank You to Tom Kilgore:
Old 05-15-2009, 03:37 PM
Photo Re: Briggs & Stratton 2. 3 horse?
here are some photos on the rod it looks like a backwards 5 ??i can till how long the rod is to much damage piston is 2.5/16 bore 2.3/8 thanks brian
ID:	54462   Click image for larger version
BRIGGS & Stratton John Ames Generators & Motors General Discussion 2 03-29-2009 01:49 PM
Briggs and Stratton 6 HP OHC Need Help! gohuge Small Air Cooled Gasoline Engines 4 02-11-2009 04:57 PM
6S Briggs and Stratton dallam1 Small Air Cooled Gasoline Engines 8 07-12-2007 12:05 AM
Briggs Stratton PB Derek Watt Small Air Cooled Gasoline Engines 1 12-21-2006 06:53 PM
WI Briggs & Stratton sparkplug54 Small Air Cooled Gasoline Engines 9 02-27-2006 02:19 AM
