Another question.
My Generac 9344-1 has a normally closed low oil pressure switch. Where can I get a normally open...
this thread has 5 replies and has been viewed 354 times
Old 05-17-2009, 03:21 PM
Attakapas24 Attakapas24 is offline
Default Another question.
My Generac 9344-1 has a normally closed low oil pressure switch. Where can I get a normally open oil pressure switch? It is 10psi and 1/8 thread.
Old 05-17-2009, 03:48 PM
Default Re: Another question.
The automotive 2 prong switches are normally open, you'll just have to ground one terminal. They are available in 1/8" pipe, you may have to look in the catalog. Mid 80's GM cars used them. When I saw the Attakapas name I figured you were in Louisiana.
Old 05-17-2009, 04:25 PM
Thanks.
Plaquemine, Louisiana.
Where are you from?
Old 05-17-2009, 05:11 PM
Gunny Gunny is offline
NAPA would probably be a good source for your pressure switch.
Old 05-17-2009, 05:28 PM
K D Redd K D Redd is offline
The Chrysler car equipped with the "Lean Burn" system has a oil pressure switch that is three terminal. The center grounds with no oil pressure and the outside two are open. When oil pressure is applied the center terminal is un-grounded and the outside two terminals are connected.
Kent
Old 05-17-2009, 07:03 PM
Originally Posted by Attakapas24 View Post
Thanks.
Where are you from?
Donaldsonville, LA
valve guide clearance question & steam engine question Sky Antique Gas Engine Discussion 3 06-07-2005 11:50 PM
