| Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer. |
The Marion 10 HPTook delivery of a nice 10 hp Marion Saturday . It was delivered from Iowa by a couple of friends...this thread has 16 replies and has been viewed 2501 times
Took delivery of a nice 10 hp Marion Saturday . It was delivered from Iowa by a couple of friends coming from Nebraska to Zack and Jack Williams home in Belmont ,WV. Will need several parts machines and the piston is stuck. I recond I will have to drag out the electrolis barrel and charger. That is just some of the fun of getting this rare little oil field engine running again. Hope to have it at Sistersville in Sept.
Will keep you all posted. Tom in VA. |
The Following 16 Users Say Thank You to Tom Weatherford:
Its always nice to chat with a freind and make things happen.
Nice looking engine. You would save yourself a little cash if you just poor some moon shine in that cylinder. Talk Soon KK |
I think you should have left it in Belmont, it would have been well taken care of
I should have Hi-Jacked that Marion before it ever left the "Nebraska Oilfields". The Marion Engine sure is nice. Can't wait to see it running Tom.
Nice to meet Jack, Zach, Tom and Bill. Also a thanks to the freight broker KK. Well after 2,200 miles in three days, were home. 5 Engines changed hands and we only lost 1 tire on the trailer. Fortunatly just a seperated belt and no blow out so we were able to get off the interstate. I'm ready for the next trip. Here are a couple of shots of the loads. |
Starting to get the Marion back in shape. I have the cylinder in electrolis to loosen piston . Hs been cooking for a week . Probley will take a couple more to loosen it up enough to remove safely.
Got a piece of 1 7/16" drill rod to make new side shaft. Will post more soon. Tom Having fun in Va. |
Had a chance to machine the intake box for the little Marion today. Will grind a 45 degree seat tomarrow after dressing a stone and making a manral to fit valve stem hole.
Rebuilt the flyball governor. Had to drill old shaft out and make a new one Hope to have the Exhaust box finished by the weekend. Tom |
The Following User Says Thank You to Tom Weatherford:
Things are looking up. 10 days in electrolis and a little help from a 100# ram, The piston is out. This puppy must have had some kinda compression. It has 3 rings per groove and 3 grooves. For some reason no oil wipe ring. But it will have one when it goes back together. The bore is rought and I will probley bore and sleeve.
Till later Tom Having fun in Va. |
Finished boring and sleeving the 10 hp Marion. The first picture is of the first pass and the second is the new sleeve. Thanks for looking.
The Following 3 Users Say Thank You to Tom Weatherford:
The sleeve is in and the gasket grooves are cut. Had to butt cut the cylinder because the sleeve was only 22" long. This will help hold the sleeve in place. The piston is next. Have to true up piston and fit the 9 old rings to the new sleeve. Hope to have this old girl up and running by the end of the month.
Thanks for looking Tom Having fun in VA. |
The Following 5 Users Say Thank You to Tom Weatherford:
Nice work Tom.
Put the first coat of paint on the bed and flywheels today. Also finished up the new sideshaft. Will start putting theold girl back together wednesday.
Thanks for looking Tom |
The Following 4 Users Say Thank You to Tom Weatherford:
The Marion has a second coat on it. Istarted putting it back together between rain showers. Just needed to see how things were fitting together. Still waiting for some parts to come in. Hope to have the ole girl smoking soon.
Thanks for looking. Tom Having fun in Va. |
My two helpers and myself have just about got the ole Marion 10 hp back together. Waiting on the two oil rings for the piston ,then the piston goes in. Have a little touch up to do and the gold pin stripping. This has been a great project. I have a freind of mine rebuilding a Wico type L mag for the Ole Girl. That was the original for the 10 hp.
Will keep you all post on progress. Thanks for looking. Tom Having Fun in Va. |
The Following 8 Users Say Thank You to Tom Weatherford:
Now its starting to look good. Keep those freinds buzzy.
KK |
The Following User Says Thank You to Kevin Kusel:
Everything hooked up and finshed. I gave the ole girl a try this afternoon. A little gas in the spartk plug hole. When the mag tripped she belched out a big cloud of black smoke. That's it one fire. She is still pretty tight. Will belt her up to a 15 hp F/M I just finshed working on for a friend and exercise her a little ,will help things. So fellows if all you get out of your Ole Girl is a little smoke, just belt her up and exercise her some. Has always helped me.
Tom |
Looking really good Tom, are you going to bring her to Sistersville? I would love to see her in action!
Got the Marion to fire up and run on it's own today. A little bit more adjustments and it will purr like a kitten. Boy doest it hit hard, I have ti run with the compression release on. I recond it is the 9 compression rings and 2 back oil rings. Will get the kinks out soon and it will be up for sale. I will bring to Coolspring in Oct. if not sold before.
Tom (Having fun in Va.) |
| Marion old fashion days to set world record for tractor parade | Cody C | Antique Tractor Talk | 1 | 07-31-2007 10:14 AM |
| Pics from Pioneer Gas Engine Show, Marion, NY | Rick I | Antique Gas Engine Discussion | 7 | 08-08-2005 12:34 AM |
| Engine Show in Marion, NY (Rochester) | Tim Claremont | Antique Engine Archives | 1 | 07-04-2002 01:42 PM |
| Marion | Pete Daniel | Antique Engine Archives | 1 | 08-14-2001 07:17 PM |
| Marion and Wauseon, OH shows | John Crist | Antique Engine Archives | 3 | 06-26-2000 10:56 PM |
