No output on model 6032-4Need help on generac generator model no. 6032-4. This unit worked great until I repaired one of...this thread has 2 replies and has been viewed 395 times
Need help on generac generator model no. 6032-4. This unit worked great until I repaired one of the cylinders. When I re-installed the cylinder, the generator did not work and has no power. What do I need to check or replace? This is on my bucket truck. Where is the voltage regulator on this generator?
WW-
The 6032-4 seems to be a somewhat obscure model. The Generac Portable web site did not have it listed in the Manuals download section. If it was supplied by the manufacturer of your bucket truck, then they might have some information. I wonder if yours is similar to the models made for RVs? There was a discussion here about Generac's Dometic TXP series a few weeks back. The TXP-45 has a model number in the 6000 range. If you can find the TXP manual (50357.pdf), it might be helpful. However it doesn't mention flashing the field, which could be what yours needs. Fred |
The Following User Says Thank You to Fred M.:
no regulator, make sure you have 12v dc to small relay in panel, some had a fuse mounted to the relay, you should have a switch to turn the generator on and off, you can hear the relay click, check brushes and slip rings if this sat for any length of time
most parts are not available for that anymore, diodes and brushes only rotor,stator and reactor coil are nla if you over speed the engine much you can through the windings out of the rotor was this unit working with this engine, are you direct connected to engine or belt drive |
| MEP-005 no AC output | na5sa | Military MEP and Aircraft Gen-Sets | 21 | 09-06-2009 12:16 PM |
| Testing 220 output on a 4KW CCK | FLHTpilot | Onan Generators | 9 | 06-16-2008 12:11 AM |
| Odd output voltage | Gunny | Onan Generators | 4 | 02-12-2007 07:22 PM |
| 12 JC Output Question 10.4kw or 8.6kw | richar22 | Onan Generators | 1 | 10-30-2006 09:15 AM |
| no output | Skip Essigmann | Generators & Motors General Discussion | 11 | 10-21-2003 11:41 AM |
