Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
Need Kubota Diesel help!
I was not sure where to put this but I thought someone on the board might be able to help. I have a...
this thread has 4 replies and has been viewed 537 times
Old 06-05-2009, 01:48 PM
oldironcollector's Avatar
oldironcollector oldironcollector is offline
Default Need Kubota Diesel help!
I was not sure where to put this but I thought someone on the board might be able to help. I have a V2003T engine with a cracked head. There are lots of the non turbocharged V2203 heads around and they look identical. But I cannot find anyone willing to tell me with any certainty if they are indeed the same. Any Kubota experts out there???
Any help is greatly appreciated!!!
Old 06-05-2009, 02:44 PM
paxman merv paxman merv is offline
Default Re: Need Kubota Diesel help!
I have used a non turbo head on a turbo Kubota engine for a while, ran a genset pretty much nonstop for 6 months until i found the correct head. Have still got the other head on the shelf incase there are problems again with the turbo one.
So! Will get you out of the crap but keep looking for the correct one.
Old 06-05-2009, 02:55 PM
These folk, info@jemengines.co.uk specialise in Kubota & they do export. Might be worth a shot if there is nothing closer to you.
Old 06-05-2009, 02:57 PM
This is their website.
www.jemengines.co.uk
Old 06-08-2009, 11:11 PM
Jeff Conner Jeff Conner is offline
Oldironcollector
You can check the Kubota Engine America website for the Kubota industrial engine distributor in GA, or call your local Kubota tractor dealer. Either should be able to help you.
Jeff
Kubota 3 Cyl hwh888 Generators & Motors General Discussion 1 04-15-2009 10:51 PM
Onan 27k with a Kubota lucas34 Onan Generators 6 01-06-2009 11:14 PM
Kubota Diesel V-1505 hwh888 Generators & Motors General Discussion 43 09-11-2008 01:06 PM
Kubota ZB-600C Motormowers Vintage Diesel Engines 6 06-24-2008 08:21 PM
Kubota ER-30 oldironcollector Vintage Diesel Engines 2 06-10-2008 12:14 AM
