Go Back   SmokStak > SmokStak® General Discussion > Alternative Fuels
Alternative Fuels
Transporting Biodiesel
Are the Polyethylene "pickup" tanks OK for blended bio or maybe just B100? :shrug: These guys have...
this thread has 4 replies and has been viewed 402 times
Old 06-06-2009, 01:52 PM
krawlr's Avatar
krawlr krawlr is offline
Default Transporting Biodiesel
Are the Polyethylene "pickup" tanks OK for blended bio or maybe just B100? These guys have a plant near me but can't deliver http://www.jatrodiesel.com/pages/ind...ge=Home&pid=10
Don Edwards
25hp Listeroid (the "ratroid")
Gravely LI
Old 06-06-2009, 03:01 PM
Smokin Bob Smokin Bob is offline
Default Re: Transporting Biodiesel
Hello:
As far as I know, poly tanks approved for fuel (not poly water tanks) are fine for any kind of diesel. The only problem I'm aware of is with ethanol. In certain older fiberglass and poly resin tanks, ethanol causes the resin to leech out and this resin mixes with the fuel to form a thick goo that, obviously, would ruin an engine and gum up everything. This, however, doesn't happen with diesel. If anyone has better information, I'd like to know also.
Bob
The Following User Says Thank You to Smokin Bob:
Old 06-06-2009, 04:11 PM
The traditional processes for refineing biodiesel use either ethanol or methanol. They attempt to remove all the alcohol from the finished product, but the residual is part of why biodiesel can eat through some materials.
Old 06-06-2009, 07:39 PM
Exclamation Re: Transporting Biodiesel
Keep it out of direct sunlight, transfer to metal tank ASAP. Do NOT store beyond 60 days! Avoid excess ambient heating (more than 75 F)
The Following User Says Thank You to Andrew Mackey:
Old 06-14-2009, 11:00 PM
krawlr's Avatar
I found a guy in Germantown, OH with 55gal plastic drums for $16 each. I bought 6, 1 for fuel and the other 5 for other projects.
I'll be adding a small shed roof to keep my tank out of the sun.(250gal steel) Probably wrap it in Reflectix too.
Don Edwards
Gravely LI
B20 Biodiesel Dslsmoke Onan Generators 11 09-30-2008 09:02 AM
Biodiesel in VA kyle k Antique Gas Engine Discussion 4 08-03-2008 12:27 AM
Transporting engines R. Kern Antique Gas Engine Discussion 8 06-08-2008 09:35 PM
Transporting Jim Stigerwalt Antique Engine Archives 0 02-04-2003 05:47 PM
transporting Jim Stigerwalt Antique Engine Archives 0 11-23-2002 06:36 PM
