MEP002 military diesel generator output selector
this thread has 6 replies and has been viewed 2832 times
Old 06-10-2009, 02:39:38 AM
hurst01 hurst01 is offline
Default MEP002 military diesel generator output selector and other issues
I have a MEP002A diesel generator that has a problem with the Hz meter reading. Sometimes when you start the generator it works fine. Most other times it stays on "0" and can not be adjusted. It looks to have a new Hz meter and a new relay.
It runs fine but the power selector switch on the left side of the control panel won't move. I was trying to familiarize myself with it and turned the switch to 208-220 3 PZ. It won't turn back and I am afraid I will break it. Is there something that locks it in place? I have another one that turns fine in either position but this one won't. Anyone have any ideas?
Thanks, Ed
Old 06-10-2009, 08:35:40 AM
K D Redd K D Redd is offline
Not worked on a MEP-002, BUT on MEP-16, 17 and others the switch is spring loaded. You turn is against a spring and when you turn it far enough the spring will trip the switch with a solid kerchunk.
Are you sure the set is making power when the HZ meter is staying on zero?
Kent
Old 06-10-2009, 03:13:44 PM
Hi Kent,
I haven't checked to see if it indeed produces power when the meter is reading zero. When I first started it it worked fine. The about one out of four times it might work. Apparently the military had problems with it because of the new meter and relay. I was hoping that someone on here had a similar problem that they could tell me about.
These are two separate generators that have the problems with the switch and the Hz reading zero. The one with the switch problem, I turned the switch all the way to the left, it clicked and won't turn back. The one with the Hx meter is on the above post.
Ed
Old 06-12-2009, 01:50:40 AM
Default Re: MEP002 military diesel generator unstable Hz
I Made a mistake on this generator. Instead of staying on zero, the Hz meter goes all the way over to 65 Hz and I can't get it to go back regardless of engine RPM. It does put out voltage according to the meter at all times.
It had been a while since I had fooled with it but tried it again this evening. The issue of the selector switch was on another generator. I guess I will have to pull the switch to se what is up with it.
Thanks, Ed
Old 06-12-2009, 09:39:12 AM
Default Re: MEP002 military diesel generator output selector
BUY a KILL-A-WATT meter to check you output frequency.
Kent
Old 06-13-2009, 09:09:53 PM
speddmon speddmon is offline
I have two MEP-003a's. They are the big brother to the 002a. The selector switch on one of mine was hard to turn when I first got it. These things are built pretty beefy, maybe there is just a build-up of dirt/rust around the switch movement. If you can get it to turn it should free up nicely. Once I got mine to turn it works like a charm now. You should have spring tension all the way to a little past the position you are going to and then it will "snap" into that position.
Old 06-14-2009, 02:56:29 AM
Mine turned relatively easy but has a lot of tension on it. It snapped in place and won't turn back. I will have to check it out. Right now I am working on another 002A with injector pump problems. It has a broken part in it. I sure hope I can find the part.
Thanks, Ed
GM Bedford diesel Delco Military genset - help please mhinkle Military MEP and Aircraft Gen-Sets 4 08-24-2011 02:09:49 AM
Testing generator output? steig lindo Generators & Motors General Discussion 10 02-14-2009 07:19:10 AM
ID diesel from a military number???? GeneratorGus Vintage Diesel and Oil Engines 4 07-29-2007 09:42:44 PM
Brass fuel selector valve/bowl BWegher Antique Gas Engine Discussion 3 09-12-2005 05:59:26 PM
No output, AC generator Arthur Generators & Motors General Discussion 1 02-24-2005 12:12:49 PM
