Smokstak Down Under
Petter Handyman fuel problem
I HAVE A 1910 PETTER HANDYMAN WHICH IHAVE RESTORED AND HAVE BEEN SHOWING FOR SOME TIME BUT I HAVE...
this thread has 6 replies and has been viewed 450 times
Old 06-11-2009, 07:10 AM
John Kilpatrick John Kilpatrick is offline
Default Petter Handyman fuel problem
I HAVE A 1910 PETTER HANDYMAN WHICH IHAVE RESTORED AND HAVE BEEN SHOWING FOR SOME TIME BUT I HAVE ALWAYS HAD TROUBLE WITH THE CYLINDER GUMMING UP. WHEN THE ENGINE IS SHUT DOWN IT SIEZES ALMOST IMMEDIATLY! (BUT IT WILL RUN ALL DAY)
THE ENGINE HAS TO HAVE THE PISTON PULLED ALL THE TIME AND SCRUBBED UP WITH MEK.
THE ONLY FUEL IHAVE BEEN ABLE TO GET IT TO RUN ON IS AVTUR OR LIGHTING KERO, ANY ATTEMPT SO FAR TO MIX IN SOME DIESEL HAS HAD NEGATIVE RESULTS.
ANYONE GOT ANY IDEA'S?
Old 06-11-2009, 07:40 AM
Images: 1
Default Re: Petter Handyman fuel problem
What sort of oil are you using? I have found some of the heavier mulitgrade detergent oils can really gum things up.
Old 06-11-2009, 08:02 AM
Hi Pat, thanks for the reply, I have tried straight mineral oil which didn't seem to make any difference so I assumed it was a fuel issue but maybe I should look into the lube side of it a bit deeper as I do tend to over oil my engines a bit.(gotta look after the old girls eh!)
Cheers John
Old 06-12-2009, 01:04 PM
Wayne Timms Wayne Timms is offline
Hi John,
I have a couple of engines which suffer from the same problem, when I just use standard kerosene. To overcome this I add 100ml of 2 stroke chainsaw/lawnmower mix to 4 - 5 litres of kerosene. It works for me, I don't know why!
Let me know if it works for you.
Regards,
Wayne
Old 06-14-2009, 08:18 AM
Thanks Wayne,
I'll give anything a go but it may be a while before I get the Petter out again, got a bit going on at the moment.
Cheers John.
Old 10-11-2009, 06:32 PM
rolfengine rolfengine is offline
hi john i agree with wayne fill your pot with bog standard 2 stroke oil, mix some in your fuel , mine will run ok all day , also make sure the compression is good, regards adey
Old 10-14-2009, 09:28 AM
Question Re: Petter Handyman fuel problem
Thanks Adey, I have been advised recently by fellow old engine men to use 'Penrite Heritage MTH' oil in all my engines.
Sounds like good stuff wadayareckon?
Cheers John.
3HP IHC model M fuel problem please help! Robert DeBord Antique Gas Engine Discussion 12 05-05-2009 08:17 PM
Petter, Bryce injection pump problem barbill Vintage Diesel Engines 2 08-21-2008 05:39 PM
Fuel problem in F 250 Diesel JHFoster Smoke, Flames & Gas (Off Topic) 36 05-22-2008 12:18 AM
IHC Fuel Pump Problem lister d Antique Gas Engine Discussion 5 10-14-2007 09:27 PM
Maytag 92 Fuel Problem Frank Douglas Maytag Engine Collectibles 6 08-02-2006 06:50 PM
