VH4D Need Help with Firing and Timing
this thread has 2 replies and has been viewed 14009 times
Old 06-15-2009, 08:58:09 PM
hdm2002 hdm2002 is offline
Default VH4D Need Help with Firing and Timing
I have a VH4D with a Magneto I changed the points. Now I need help timing the Mag back to the engine. What is the firing order? What is the rotation for the mag? Any help would be great.
Old 06-16-2009, 09:22:44 AM
Mike Hole Mike Hole is offline
Default Re: VH4D Need Help with Firing and Timing
Firing order.1,3,4,2 clockwise viewiing from the cap end of the mag.No.1 cylinder is the cylinder nearest the fan-flywheel of the engine in the left bank and No.3 is the other cylinder in that bank.No.2 is across the engine from No.1 and No.4 is across from No.3 Hope this helps. Mike
Old 06-18-2009, 12:29:34 AM
fredpollard fredpollard is offline
Once you have the mag timed to the engine. Place the engine at top dead center for number 1 cylinder (TDC). To do this remove spark plugs and rotate engine in the direction it normally runs. Place thumb over spark plug hole Number 1 while turning the engine. When there is pressure against the thumb and air is forced out the spark plug hole the engine is on compression stroke for #1 cylinder. Continue to rotate the engine until the zero degree timing mark is lined up with the timing mark on the flywheel.
Without the engine running the points should open just before or at TDC. Place a continuity light checker across the points and rotate the magneto back and forth until the light goes out. At the point that the light goes out while turning the engine in the proper direction the spark should fire for number 1 Cylinder. Rotate the magneto housing so the light goes out at TDC. This should be good enough to start the engine.
Start the engine as the engine speeds up the timing should advance. Check with timing light. If it does not change check the timing advance mechanism.
VH4D Wisconsin overbored Richard F Wisconsin Engines 14 09-18-2009 09:47:40 PM
VH4D Wisconsin Engine Richard F Generators & Motors General Discussion 10 06-01-2009 11:28:11 AM
Dating a Wisconsin VH4D Yasmar Wisconsin Engines 1 04-27-2009 12:30:52 AM
VH4D Wisconsin Richard F Wisconsin Engines 3 05-12-2008 12:51:19 PM
Wisconsin VH4D Chandler Wisconsin Engines 2 12-29-2007 05:21:56 PM
