Briggs FH flywheel
Hi I have an FH that needs a new flywheel, I swapped it out with a later FH flywheel and it...
this thread has 1 replies and has been viewed 578 times
Old 06-15-2009, 10:00 PM
Bob Kurtz Bob Kurtz is offline
Images: 60
Default Briggs FH flywheel
Hi
I have an FH that needs a new flywheel, I swapped it out with a later FH flywheel and it bottomed out against the breaker points. upon a close inspection the later flywheel has a bigger mounting hole, has anyone else ever experienced this? I thought they all used the same flywheel.
Bob
The Following User Says Thank You to Bob Kurtz:
Old 06-16-2009, 02:15 AM
Sky
Default Re: Briggs FH flywheel
Never had that problem. And i've made the swap from one of the most early FH flywheels to one of the latest. No troubles. Could be that flywheel is worn in an unknown way=enlarged hole. There is an old time trick to correct that. Just like they did on old Model T ford hubs. Cut a thin strip of brass or aluminum and wrap it around the shaft. wedging it against the flywheel hub and shaft which also spaces the flywheel OUT a little but it shouldnt hurt anything. If you dont have a thin strip of brass, use an aluminum can. I found that "Hobby Lobby" ( A hobby and crafts store ) has brass strip. It was in the models section. Next time i need shims thats were i'll go.
Briggs Mod 19 Flywheel Nut LeadHead Small Air Cooled Gasoline Engines 4 02-26-2009 05:29 PM
Briggs 8B flywheel Mike S Small Air Cooled Gasoline Engines 1 10-22-2007 01:04 PM
Briggs flywheel Key (Help) Smoke Small Air Cooled Gasoline Engines 20 05-07-2005 05:04 PM
Briggs 6 flywheel key Chris Kirk Antique Engine Archives 6 04-20-2003 08:54 PM
Briggs FH Flywheel Jim Sherman Antique Engine Archives 0 03-27-2001 11:56 AM
