Smokstak Down Under
Jacko Steam/hotwater system info
Hi all, I was just wondering if anyone can add any info on a "Jacko" steam/hot water system....
this thread has 4 replies and has been viewed 281 times
Old 06-18-2009, 09:55 PM
WilliamInOz WilliamInOz is offline
Question Jacko Steam/hotwater system info
Hi all,
I was just wondering if anyone can add any info on a "Jacko" steam/hot water system. Could one of these be modified to take steam pressure on 20-30 psi?
All the knoweldge i have on these is that they had a weighted saftey, sight glass and guages.
Cheers, Will
Old 06-22-2009, 03:37 AM
Eric Schulz's Avatar
Eric Schulz Eric Schulz is online now
Default Re: Jacko Steam/hotwater system info
Just extracted this from the archives. Looks like if you have a No 3 or 4 size you have 50psi to play with. I have seen one of these powering a steam engine.
Eric
The Following User Says Thank You to Eric Schulz:
Old 06-22-2009, 06:16 AM
Thanks Eric. Ill get a picture posted of the one in the shed.
Cheers, Will.
Old 06-22-2009, 10:55 AM
Ironsides Ironsides is offline
Must admit that I haven't had anything to do with these systems,have however seen some scary hot water heating systems around the place seem to remember seeing relief valves with weights attached on some strange hot water systems when playing sport in the bush over the years.Seem to remember one exploding some years back in WA at a football ground,wasn't there thank god.Spent 20 years in the regular army we used a " put and take"system,(you had to have 2 buckets, pour cold water in the top at one end and catch the outflow of hot water at the other end).Inlet pipe needs to go to low in the tank,outlet off the top.Water heated by whatever is available,normally wood under a 44 gallon drum layed on its side,Norm
Old 07-12-2009, 12:50 AM
Just had a look yesterday at this joack system its got 50-60psi tops on the gauge looks like it can take some pressure.
Delco Light System Info Needed Donald A Smith Antique Gas Engine Discussion 2 01-09-2007 01:18 AM
info about steam engine fordson22 Stationary Steam & Traction Engines 10 07-13-2006 11:52 AM
Steam whistle info. help Fairbanks_Kid Stationary Steam & Traction Engines 4 04-24-2002 12:51 AM
Info on steam engine Ken Meeks Antique Engine Archives 0 03-28-2001 06:22 PM
O+S steam engine info Paul Gray Antique Engine Archives 1 02-09-2001 11:58 PM
