Put magnets back on flywheel?
this thread has 3 replies and has been viewed 2837 times
Old 06-24-2009, 03:14:01 PM
dhiesel dhiesel is offline
Default Put magnets back on flywheel?
I have a Kohler K301, well 2 actually. One on a working Gravely and one I am rebuilding that is newer. the bolt up is no problem, but the flywheels are a little different. One bolts to the crank, the other uses a nut.
The newer bolt on crank threw the magnets, all intact.
What i would like to know is the position of the magnets on the fly wheel-- North to south clockwise? // or does it matter as AC to the rectifier?
N S N S --->
Old 06-24-2009, 04:05:16 PM
Lead Head Lead Head is offline
Default Re: put magnets back on flywheel?
the position of the magnets does not matter, as its AC. The only thing you have to ensure is that they do alternator N-S-N-S--- , and try to space them evenly as possible. Use a good grade epoxy, and clean up as much rust as possible. Don't use a fine grit sand paper either, as you want the bare metal to be somewhat rough for the magnets to adhere better.
The Following User Says Thank You to Lead Head For This Post:
Old 06-24-2009, 09:08:13 PM
Brian Lynch's Avatar
Brian Lynch Brian Lynch is online now
Images: 24
Two questions.... does this engine have a flywheel magneto? Or does it have a battery & coil system? I have seen lots of equipment come thru my shop with this problem -loose magnets. I use Lord products Fuzor 100 to rebond the magnets to the flywheel. This is the stuff they use to bond plastic car parts to metal with. Any good body shop supply store that's worth a damn will carry it. It's pricey, but it works great.
Back to the ignition question....If this engine has a ignition coil under the flywheel, make sure all the magnets are spaced in thier correct place or you get no spark. It's not critical if the engine has battery coil. The magnet ring in this application is used only to induce an alternating current field for use with a regulator to maintain the battery for starting or other electrical load.
The Following User Says Thank You to Brian Lynch For This Post:
Old 06-26-2009, 03:35:57 PM
I do have a battery and coil ignition, so the magnets just maintain the battery at the regulator.
I appreciate the info on the adheisive, that was going to be my next question.
Tecumseh H35 flywheel magnets Larry Dunlap Small Air Cooled Gasoline Engines 6 06-21-2012 12:07:28 AM
Charging Flywheel Magnets Don Naismith Small Air Cooled Gasoline Engines 14 10-28-2011 11:31:50 AM
Maytag "Model 92" Flywheel Magnets Mike S Maytag Engine Collectibles 10 12-26-2008 11:29:45 AM
Had to mill the back side of the Br6 flywheel Brian.P Small Air Cooled Gasoline Engines 4 12-22-2008 10:11:35 PM
magnets Tim Ray Antique Engine Archives 4 07-21-2002 10:22:18 AM
