Welding Shop
Old Hobart gas driven welder with 2 cyl Wisconsin
Hello I just acquired a Hobart gas driven welder. The tag says it is a model#G-235 with a Wisconsin...
this thread has 8 replies and has been viewed 692 times
Old 06-29-2009, 11:52 PM
Howie Marion Howie Marion is offline
Default Old Hobart gas driven welder with 2 cyl Wisconsin
Hello I just acquired a Hobart gas driven welder. The tag says it is a model#G-235 with a Wisconsin WTSC THD-2. It is an electric start model. My question is about the battery and about any avalible manuals. Is the required battery 6volt or 12 volt? is it positive ground or negative ground? any avalible manuals? Thanks The tag also reads specs 4130 ser. AAW46778
Old 06-30-2009, 12:18 AM
alejandro barrera alejandro barrera is offline
Default Re: Old Hobart gas driven welder with 2 cyl Wisconsin
Hi. Good to know there are someone who own an old Hobart. Exellent engine and welder. You may contact to literature@millerwelds.com for the owner's manual (Miller was aquired Hobart years ago) the owner's manual are so complete It works good for mine. Please post a picture. Good luck. You can watch the video of mine http://www.youtube.com/metalworker85
Old 07-01-2009, 08:40 PM
Dempster Dempster is offline
Hobart has a site also. The owners manuals and product literature are under the service & support section.
Hobart Manuals
http://www.hobartwelders.com/service/owners-manuals/
Hobart Welders
Should be a tag on your starter or generator that states 6V or 12V. Your engine is a Wisconsin THD model. Manuals for it can be downloaded from the Wisconsin Motors site.
Wisconsin Motors parts manuals and accessory manuals
http://www.wisconsinmotors.com/partcatalog-ex.html
Old 09-04-2009, 11:13 AM
mark gerdes mark gerdes is offline
i have a hobart welder with wisconsin 2 cyl. engine and it uses starter windings on welder armature to start machine. it is 24 volts. 2 12 volt garden tractor batteries.
Old 09-12-2009, 01:36 AM
swampy swampy is offline
Howie- I have a hobart/wisconsin and is a G-2235, are you sure you didnt miss a 2? I have a service manual I can send by email. Mine is 6 volt pos ground. Just to compare mine is 5kw gen, 200amp/24 volt dc welder, wisconsin 2 cyl THD @ 1800 rpm.
Good luck
Old 10-03-2009, 09:34 AM
stash9799 stash9799 is offline
Hi I just bought a G 213 powered by a TJD Wisc. I'm trying to find out if mine is 12V or 24V? Mine also starts through the armature. I would love to ask you more questions if you have the same machine. Thanks
Old 11-12-2009, 07:31 PM
leroy jones leroy jones is offline
I just got my hands on a hobart model gw 2235 and i need help finding the parts to adjust the welder.
Old 11-12-2009, 08:19 PM
Owen Bosma Owen Bosma is offline
This hobart welder is 24 volt start 2 12 volt garden type baterys hooked up in series.
..... Owen
Old 11-12-2009, 09:01 PM
Service
http://www.hobartwelders.com/wheretobuy/?svc=service
Hobart Manuals
Hobart Welders
The Following User Says Thank You to Dempster:
A.O. Smith engine driven DC welder richard welk Welding Shop 17 02-28-2008 02:00 PM
old hobart welder Dan Potter Welding Shop 1 06-16-2007 02:54 PM
FS: Hobart Engine-driven Welder, Very Heavy Duty, in Oregon dozer Welding Shop 0 08-05-2006 06:18 PM
Old Hobart Welder DaveHath Welding Shop 7 01-10-2006 09:17 AM
DCC-353-P Hobart Welder Rob-n-LA Welding Shop 2 07-17-2004 04:55 PM
