Smokstak Down Under
Old iron tinkering question - tapered pins
Hi all, I'm working on a gearless olds which has an exhaust valve which has two collars fixed...
this thread has 4 replies and has been viewed 321 times
Old 06-30-2009, 06:48 AM
Michaely Michaely is offline
Default Old iron tinkering question - tapered pins
Hi all,
I'm working on a gearless olds which has an exhaust valve which has two collars fixed to the stem which are part of the spring retainer and governor latching/unlatching action. (kind of hard to explain - not even sure I understand myself). The collars are held on with tapered pins. The whole lot has to be remade due to severe rust. Its no trouble to get the pins either bought or made but I have no idea how to drill a itty bitty tapered hole for the pins to lock into. Any ideas - 'specially those that work - would be much appreciated. I could cheat and press fit in a straight pin in or one of those modern rolled steel pins. Kind of prefer to try the old method though. Thanks - Mike in Orange, NSW, Australia
Old 06-30-2009, 07:10 AM
Oldsiron's Avatar
Oldsiron Oldsiron is offline
Default Re: Old iron tinkering question - tapered pins
Hi Michael,
My early 5A Olds has tapered small lock pins on the valves.
We made new valves out of CAT v12 inlet valves(nice and soft), the exhaust ones are to hard to machine,
the tapered holes were drilled to the small end diameter of the spring retainer hole, then we used a tapered reamer to taper the hole.
hope this makes sence
Old 06-30-2009, 08:09 AM
Tom Martin Tom Martin is offline
Any large machine supply outfit should have the taper pin reamers and pins. Try MSC http://www1.mscdirect.com; McMaster-Carr http://www.mcmaster.com/ or ENCO http://www.use-enco.com/. Those are all in the US, but I'm sure there are outfits in Oz that have the same stuff.
Old 07-03-2009, 05:56 AM
Thanks guys - wasnt sure if tapered pins were in use these days, but seems they are.
Mike
Old 07-03-2009, 07:19 AM
Oldsiron's Avatar
Hit N Miss have taper pins in their parts catalogue.
I bought some parts of them, with excellent and fast service
http://www.hitnmiss.com/
regards Chris
Large Tapered Flywheel Key AndyG Stationary Steam & Traction Engines 14 04-10-2009 06:34 PM
Tapered pin, drilling, installing etc vicp Machine Shop and Tool Talk 10 07-08-2008 06:40 PM
Tapered ring ends Gerry Boose Antique Gas Engine Discussion 3 06-22-2008 12:02 PM
Tapered Gib Head Keys Tom Kilgore Machine Shop and Tool Talk 2 04-06-2008 06:53 AM
Tapered Gib Keys stan agacinski Antique Engine Archives 7 10-27-2002 04:27 PM
