Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
SA 200 Welder needs a new Continental F162
Hello, I am new to the group but I would bet someone here knows where I could get a Continental...
this thread has 6 replies and has been viewed 712 times
Old 07-02-2009, 08:22 AM
sduplessis sduplessis is offline
Default SA 200 Welder needs a new Continental F162
Hello,
I am new to the group but I would bet someone here knows where I could get a Continental F162 motor. Running would be great, but all it needs to be is rebuildable. I recently aquired a Lincoln Welder and the previous owner left it outside without the exhaust covered.
Needless to say the engine is a mess and it would be cheaper if I just found another one.
I have found some engines in old fork lifts but they are too far away. I live in the louisville, ky area
Thanks for all your help.
Sam
Old 07-02-2009, 08:48 AM
Bill Stafford Bill Stafford is offline
Default Re: SA 200 Welder needs a new Continental F162
If you don't find something local we used this guy for our 2- Miller 200amp. gas drives. They are a commerical outfit and prices will be higher than you local fixer or back yard storage warehouse, but they have a lot of options
Good luck: Bill
Foley Marine & Industrial Engines, Inc.
200 Summer Street, Worcester, MA 01604
1.800.233.6539
Bill
Old 07-02-2009, 08:58 AM
I have found a few commercial motor sources too but they are selling rebuilt for $1700-2000. I am hoping I can find something much less expensive because I can do the engine work.
Thanks,
Sam
Old 07-02-2009, 12:14 PM
Be carefull here. Not all 162 engines in a forklift are like those in a welder. How far do you want to go for parts and is the key item a block?
Old 07-03-2009, 02:59 AM
I have found a F163 that came out of a lincoln welder. I think the key difference is it has a distributor instead of a mag. I will check it out tomorrow and see if it looks like a fit.
Old 08-09-2009, 05:05 PM
I believe I am going to part out this engine and welder. Anyone know best place to list the magneto, starter carb etc?
Old 08-21-2009, 03:37 PM
Dempster Dempster is offline
Can list parts on welding forum site for sale ads or enginads.com here. Welder parts and older welders aren't bringing as much now as many welders nation wide are out of job right now. You could have adapted a F163 into it or rebuilt one of them for tad less than F162. What you got quoted is pretty much the going rate to rebuild a F162. Listing several links you can check with.
http://www.montesequipment.com/
http://www.aws.org/cgi-bin/mwf/forum_show.pl
http://www.weldingweb.com/
http://www.stumpfsweldingsupplies.com/
http://www.billswelderrepair.com/Engine-Drives.html
http://www.mandmsurplus.com/
http://www.foleyengines.com/Default.aspx
http://www.parossmachinery.com/
http://www.enginepowersource.com/htm...verhaul%20Kits
Parts Distributors, Parts & Service Manuals for Continental & Wisconsin
http://www.wisconsinmotors.com/partcatalog-ex.html
http://www.continentalengines.com/
Continental F162 starting problems bkahler Onan Generators 12 12-16-2007 02:44 PM
Continental AA7 Sean B. Small Air Cooled Gasoline Engines 7 02-17-2006 06:19 PM
Continental F-163 Paul J. Morrison Generators & Motors General Discussion 2 01-23-2005 03:28 PM
y112 and f162 end plate compatability Merritt Burrus Generators & Motors General Discussion 0 12-01-2003 04:43 PM
Continental E4 Don Shilling Antique Engine Archives 0 08-12-2003 11:03 PM
