Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
New toy: Gravely mower
this thread has 7 replies and has been viewed 4591 times
Old 07-21-2009, 05:54:45 PM
Regs Regs is offline
Email NOT Working
Images: 5
Photo New toy: Gravely mower
Bought this the other day for around $100. Unsure which model it is though, looks to be a later model with the Robin motor that's fitted to it. The tag on the handle says S/N 00524197. Robin motor does not go because 2 out of 4 inner flywheel magnets are missing and one is just about broken chunks, so I am hoping to try and fit an original gravely motor to it. I have the gravely mower, given to me from a friend but needs a piston, cylinder head, valves and carb to complete it.
ID:	58973 Click image for larger version
Old 04-09-2010, 12:55:37 PM
udmitchell udmitchell is offline
Default Re: New toy: Gravely mower
One of the best places to find new old stock, reworked, or otherwise good parts is Richard's Lawn & Garden in west Virginia. He has everything you would ever need from a few parts to a brand new engine. Only problem is price. He has all the best Gravely stuff and you have to pay for the best stuff...my humble opinion. To help you out check www.oldgravelys.net for just about any owner's or service manual you could need. Hope this helps. Good luck.
Old 04-09-2010, 03:56:45 PM
reh1119 reh1119 is offline
What you have is an old super convertable that used to be powered by either a 6.6 or a 7.6 hp.gravely engine dating anywere from the mid to late 50's to the late 60's.I have 2 of this model and still use them.
Thanks.
REH1119
The Following User Says Thank You to reh1119 For This Post:
Old 06-02-2010, 02:41:13 PM
jepics jepics is offline
Based on the dash panel and hitch, it is likely to be a Commercial 12 or L8 model (1969 or later machine). Check the forward housing (casting) on the lower left side in front of the wheel for an ID tag. Starts with letter "J" and 5 numbers, like: J-12345. With that number, you can look it up in a chart to determine the heritage.
John D
Old 06-02-2010, 06:15:23 PM
gwbgravely gwbgravely is offline
According to the serial # of 00524197, it would be a 1981. As jepics said the hitch and dash panel are probably orginial and a give away as to the model. It orginially had a kohler engine on this tractor, either an 8 hp - Model 5260 or a 10 hp - Model 5460 or a 12 hp - Model 5665. I am not sure if a regular T head gravely engine will fit up on this tractor. It would be best to get a kohler engine of whatever horsepower you desire.
The Following User Says Thank You to gwbgravely For This Post:
Old 06-03-2010, 07:18:06 AM
FlaWaterman FlaWaterman is offline
The answer is no. A Kohler or later powered unit uses 4 clearance holes to attach the adapter to the tranny. Bolts come in from the front. Gravely engine requires tapped holes for all but one stud and the bolts come in from the rear thru the engine.
The Following User Says Thank You to FlaWaterman For This Post:
Old 06-04-2010, 04:27:03 AM
Email NOT Working
Images: 5
Well the chances of finding a kohler for it are fairly slim, as people want a fair bit for the big ones and I was lucky to get the gravely for less than what people usually try to sell them for. Fortunately I did find another flywheel for the robin motor and got it running. The last owner left it outside and when I drained the gearbox i got about half a cup of water with it. Recently I discovered little broken bits of bakerlite in the bottom of the gearbox, and although I stripped the entire thing down, I couldn't find any traces as to where the bits of bakerlite came from.
Old 06-04-2010, 08:54:50 AM
Elden DuRand's Avatar
Images: 6
Regs:
THe Bakelite probably is material from the bands. The earliest L models had metal-to-metal bands. The later ones had lined bands.
Since yours is a later model, what you found is probably what was once on the bands.
Like the Model T Ford, you find lots of interesting bits in the sump.
Take care - Elden
Take care - Elden
http://www.eldensengines.com
Gravely Tractors Nick Stanley Garden Tractors / Mowers / Scooters 24 04-29-2014 06:53:59 AM
Gravely Model D Junkologist Garden Tractors / Mowers / Scooters 15 06-03-2010 07:29:54 AM
Older Gravely L I drmag64 Unidentified Engines 2 04-30-2009 06:16:32 PM
gravely skip landis Antique Engine Archives 3 06-02-2004 08:20:56 AM
Gravely walk behind Marty Antique Engine Archives 5 09-23-2002 03:59:46 PM
