Onan microquiet 4000 fault code 32 problem
this thread has 11 replies and has been viewed 12435 times
Old 07-22-2009, 12:39:43 PM
trialbyerror trialbyerror is offline
Default Onan microquiet 4000 fault code 32 problem
I had a problem on my generator this past trip. I accidentally turned on my inverter while the generator was still plugged into the trailer, the generator was not running at the time but still plugged into the system. As a result my inverter fried and now my generator will not start. It starts for about 3 seconds if i keep the start button pressed but then dies and flashes fault code 32. So I must have fried something in the gen as well. Oil is fine and battery connections are good, thats all the help i got from the operation manual. Anyone have an actual service manual that has test procedures for this code and particular model. Or just some help on what to test. Thanks in advance. John.
Old 07-22-2009, 01:58:08 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Onan microquiet 4000 fault code 32 problem
http://www.smokstak.com/forum/showthread.php?t=56022
Bruce in alaska
Old 07-22-2009, 02:16:32 PM
Default Re: Onan microquiet 4000 fault code 32 problem
Sorry about no info on the gen, will post updated model and serial number when i get home. Thanks, john.
Old 07-22-2009, 04:21:20 PM
Ok here is the Model and serial number.
Model # 4KYSA26100K
Serial # I010282346
Old 07-22-2009, 04:41:20 PM
EricWood's Avatar
EricWood EricWood is offline
tbe,
See if these help you out at all.
(you may need to save the attachments to get them to open up large enough to print out)
eric
The Following User Says Thank You to EricWood For This Post:
Old 07-22-2009, 05:12:19 PM
Thanks for the manual.
Old 07-23-2009, 12:11:36 PM
Does anyone have a complete service manual?
Old 07-23-2009, 03:38:59 PM
EricWood's Avatar
PM Me with a valid email address. Can get an e-copy today, but not immediately available.
eric
Old 07-23-2009, 04:53:36 PM
Thanks, its on its way.
Old 07-27-2009, 11:33:24 PM
Ok, so i did some testing according to a troubleshooting guide and this is what i found. I have no AC output during the few seconds that it will run. Next the guide said to check the field flash for proper 12VDC . I could not find an accurate description for checking this but I did find that the field flash is F1 and F2, is this correct? If so i followed the wiring diagram and it shows those wires going to P1-1 and P1-10 on the control board. I tested from chassi ground to P1-1 and had no voltage while it was running or cranking, also ground to P1-10 and same readings. If this is correct, the manual says its a bad control board. Any thoughts on this or any more things to check?
Thanks, John.
Old 08-04-2009, 12:39:06 AM
robsimmons robsimmons is offline
Originally Posted by EricWood View Post
tbe,
eric
Eric, any chance you could post the pager for Code 27?
Old 08-04-2009, 12:42:32 AM
sorry I that should have said pages for code 27 or possibly send me the same manual you sent trialbyerror?
New Onan fault codes? Cat Man Onan Generators 12 05-28-2013 03:36:02 PM
Onan CCK 4000 Generator Jerry B Onan Generators 5 07-06-2009 12:50:25 PM
Onan 4000 Emerald Series westt Onan Generators 5 07-06-2009 01:42:54 AM
Onan Marquis Gold 5500 fault rcmech Onan Generators 2 06-17-2008 08:04:22 PM
wendals paint code problem Bruce P Pederson Paint Shop 3 12-30-2002 03:49:41 AM
