Welding Shop
Lincoln SA-180 carbon brush holder & brushes
I had the 2 rear bolts sheer on me and turned the brush holder into the housing and melted the...
this thread has 8 replies and has been viewed 286 times
Old 07-29-2009, 07:44 AM
ciggs ciggs is offline
Default Lincoln SA-180 carbon brush holder & brushes
I had the 2 rear bolts sheer on me and turned the brush holder into the housing and melted the springs that hold the carbon bushes. Have to make a modification to prevent this, seems like an engineering problem of sorts.
I'm looking P-37-G (old style) or P-25-N (newer style) carbon brush holder and the carbon brushes (3/8" thick 5/8" wide and about an 1" long)
Any ideas where I can these and the part numbers
any distributors in Ontario Canada?
ID:	59576   Click image for larger version
ID:	59577   Click image for larger version
ID:	59578   Click image for larger version
Old 07-29-2009, 12:19 PM
pops pops is offline
Default Re: Lincoln SA-180 carbon brush holder & brushes
So, did the bolts shear, or just came loose? Use grade 8 bolts if they sheared. Use safety wire if they came loose. Things that vibrate need safety wire! Be sure to install the wire where the pressure of the wire TIGHTENS the bolt. This is a "positive" safety wire. I worked on AF jets for years. Important things are safety wired. Otherwise, they fall off. James
Old 07-30-2009, 07:26 PM
Dempster Dempster is offline
I went to LincolnElectric.com clicked on location and got this Canadian link. At the bottom click on "where to buy" to find dealers up there. Quick Links at the top will take you to Service and on lincolnelectric.com quick links take you to manuals download page.
http://www.lincolnelectric.ca/
http://www.lincolnelectric.com/
Old 07-30-2009, 07:54 PM
JD Canuck JD Canuck is offline
Contact John Lowes at Schnurr Electric Co Ltd in Guelph (519) 822-5480, if its Linclon he should be able to help you.
Old 07-30-2009, 10:54 PM
thank you for the replies
No the bolts were sheered off, two 1/4 inch bolts, there not really enough room for any improvements or modifications to the original plate , like for adding a steel sleeve to stiffen the threaded area of the bolt which is about an inch to the bearing housing cage or even a larger bolt. which also keeps the brush holder in place. I think it just a slight bending when load is applied and and the release of the load and perhaps some end to end play.
I might be able to get away with a thin hardened steel sleeve 1/16 thickness, the original plate should have been larger in diameter.
I work with some machinists I could get them to machine me a larger bearing cage plate and add in for larger bolt with a steel sleeve, I was also thinking of adding in couple of springs to the brush holder cast steel housing to absorb the load motion to the outer case housing lessen the flexing under load. the cast piece is insulated as well.
John Lowes at Schnurr Electric Co Ltd in Guelph I recall this place when I was on the road working in the quarry near there. I'll give them a call tomorrow.
Old 08-06-2009, 09:39 PM
well I finished working on the armature part update for those who have simular machines or problems, and the curious lol
I have a manufacture listing for the carbon brushes
http://www.helwigcarbon.com/products/index.aspx
63-376221
Thickness 0.375''
Width 0.625''
Length 1.25''
Bevels: 0/10
Categories: Brush, Tamped Single Shunt
Common Applications: Welder
Grade: H49
Motor Manufacturer: Lincoln
Shunt Length: 2.38
Style: Q53
I made an inquiry as to the springs through there e-mail hopeful they have and cheap!
Name:	Q53 carbon brush.jpg
Old 08-06-2009, 10:07 PM
Armature repair photo 22 is the final result photo21 shows the tig weld weld on the 5/16" nut onto the bearing backing plate, the shank bolt is 3/4" x 3/8" with a coarse 5/16" 18 thread, I had to drill and tap the old 1/4" one, I originally got a 1" length but ran into the problem with the threads running to far past the bearing backing plate, cutting the tread down only would have left 1/2 of a thread into the plate fully tighten down. The 5/16 nut did the trick perfectly and giving 1" length
photo 20 shows the nut before tig welded I tighten the nut onto the shank bolt and tightened it to the bearing backing plate I also marked the nut with with a marker and rounded off the edge of the nut on the sander to allow better fit to the machined groove photo 19
ID:	60294   Click image for larger version
ID:	60295   Click image for larger version
ID:	60296   Click image for larger version
Old 08-07-2009, 12:07 AM
photo 17 and 16 show the groove machined into the bearing housing to allow for clearance of the larger bolt, the two bolts cost $3.50 cnd the machining and tig welding was free perks of work the first 2 bolts the guy grabbed were for a machine and cost $94.00 cnd I thought he was kidding lol ouch!
photo 13 shows the fitting to the beaning backing plate after sanding the 5/16" nut, the final thing will be to drill the housing to 3/8".
ID:	60308   Click image for larger version
ID:	60309   Click image for larger version
The Following User Says Thank You to ciggs:
Old 08-11-2009, 01:03 AM
Looks like some re-engineering there. Hope it works okay. Thanks for the link on the brushes.
Carbon Brushes? Jason Generators & Motors General Discussion 3 01-25-2009 11:53 PM
Onan Carbon Brushes ListerDiesel Onan Generators 7 11-23-2008 01:19 PM
Carbon brush connection - Glue or Cement Doogdoog Generators & Motors General Discussion 21 07-07-2008 12:00 AM
Advice on repairing a brush holder or parts (pincor) HawaiianTim Generators & Motors General Discussion 3 09-22-2005 02:45 AM
brush holder for bi polar Larry Healey Generators & Motors General Discussion 0 09-10-2001 09:06 PM
