Smokstak Down Under
Fordson Power Major
Have finally got my old Power Major up and running,need to change engine oil filter and diesel...
this thread has 8 replies and has been viewed 465 times
Old 07-30-2009, 11:12 AM
Ironsides Ironsides is offline
Default Fordson Power Major
Have finally got my old Power Major up and running,need to change engine oil filter and diesel filters,does anybody have current Ryco numbers for replacement filters,(in Australia).Forgot to get the engine number,will get it this weekend,many thanks Norm
Old 07-31-2009, 08:36 AM
sumpoiler sumpoiler is offline
Default Re: Fordson Power Major
I have an old ryco book @ work i will have a look and let you know tomorrow.
Old 07-31-2009, 11:00 AM
Many thanks,tried local Ford dealer he suggested Barr and co so that will have to be my backup if you have no joy thanks,Norm
Old 07-31-2009, 10:50 PM
Steve Shearman Steve Shearman is offline
Going on my book the Power Major was made between 1958-64 the lube filter is quoted as Ryco filter R2061P primary fuel filter is R1106P secondary fuel filter isR2004P
Old 08-01-2009, 09:57 AM
Steve,many thanks for your valuable help---haven't been out to the shed yet but I believe some of those numbers are the same as my old Case Comfort King.Once again many thanks,Norm
Old 08-01-2009, 08:54 PM
Thanks steve you beat me to it>
Old 08-02-2009, 10:19 AM
Sumpoiler,many thanks also for your indication of assistance.My tractor is numbered 5F759-163-4529,these numbers are located on the firewall at the rear of the engine stamped onto an aluminium plate.Can anyone confirm this is the engine number etc as I cannot locate one anywhere on the motor.Many thanks,Norm
Old 09-01-2009, 03:45 AM
Finally found the engine number,located on top of the bell housing above the starter motor.
Number is 1514?565,(number 4 could also be a lazy 0).
Can anyone confirm if this tractor is a Fordson Major or a Power Major ?
Bonnet says Power Major but bonnets can be replacements.
Many thanks,Norm
Old 09-01-2009, 04:20 AM
Eric Schulz's Avatar
Eric Schulz Eric Schulz is offline
Power Major, made mid 1959.
Eric
The Following User Says Thank You to Eric Schulz:
Fordson Super Major Hydraulic Ram Pump Kevbus Antique Tractor Talk 1 02-02-2008 08:15 PM
Fordson Major Diesel, Power Major, & Super Major David K Antique Tractor Talk 14 11-25-2007 05:12 AM
Fordson Major deisel stuck engine trouble maybe ?? Ron Davis Antique Tractor Talk 6 12-15-2006 09:15 PM
Stewart little major Ihorse Antique Gas Engine Discussion 1 04-17-2006 04:02 PM
MAJOR BREAKTHROUGH Harry Antique Engine Archives 26 10-27-2004 01:08 AM
