White/Hercules D3000 6 cyl Starter IDSomeone stripped the starter from my gen set and now I am clueless as to the model /make to replace...this thread has 3 replies and has been viewed 246 times
Someone stripped the starter from my gen set and now I am clueless as to the model /make to replace it. The jobbers I have contacted do not have a listing for this engine, It looks like a direct drive although some starter shops have pointed me to gear reduction units.
It is a three bolt mounting and it would be nice if it were 12v. Anyone knowledgeable ----I think the engines birth was arround 1986. Engine model on tag is White D3000x190 mfg by the Hercules Motor Corp. Is this a Delco -- Autolite ???? |
do you have a photo of the starter mounting and ring gear if the bolt size is 5/8 a 42mt delko off a truck will probly work but you need to make sure you have right bindx to fit your ring gear .how many cubic inches is the engine i will half to look for it .i have a book that shows starter apacation by cubic inches.
You might contact a a White, Oliver, Minnie Mo ag dealer as the engine on your generator was also likely used in their equipment.
Kent |
See Eric L's 6-6-08 Herc DD298 etc thread here (comes up on search Hercules D3000) for a discussion of Herc similar displacement engines, and John S's suggestion to try Jerry Biro.
Jobbers and M & M surplus both mention starters, but I assume they'd be $$$$...don't know if herculesengines.com has starters, nor anything about their prices. On using a starter from a similar displacement engine, I'd guess--GUESS--you'd have to be sure the ring gears and the bendix gears were the same, the right distance from the mounting to the ring gear, etc, AND if the proposed starter was designed for similar compression and usage. A number of Google hits come up on "Hercules D3000 starter". Good luck. |
| 60rh0z71 White Hercules generator | Richard123 | Generators & Motors General Discussion | 8 | 04-02-2008 08:52 PM |
| Does a FB Starter Crank work on a Hercules? | amerunit | Antique Gas Engine Discussion | 8 | 07-24-2007 05:35 PM |
| 8hp Hercules starter | Tilinghast | Antique Gas Engine Discussion | 10 | 06-03-2006 11:31 PM |
| White | Patrick M Livingstone | Antique Engine Archives | 0 | 04-13-2002 05:45 AM |
| White Gas ? | Bill | Antique Engine Archives | 14 | 06-10-2001 12:41 AM |
